Results 1 to 16 of 16
    Feb 2006
    brake or headset?
    When i front brake i feel the headset loose when i check it while not riding seems ok unless i seat on the top tube and push hard while front braking. could it be the front v brake the problem or the 4 year old aheadset? Thx
    The easist way to check the headset is to turn the front wheel to the side ,grab the front brake and rock the bike back and forth while holding the the bottom headset bearing cup. V-brakes can shutter ,clean off the rim with some light sanding or steel wool. Have you checked the wheel bearing/quick release?
    Feb 2006
    When i turn the wheel on the side, its fine. only when i am on the bike and front brake it does it
    Reputation: 006_007's Avatar
    Quote Originally Posted by Markleo View Post
    If you have the front wheel/bars rotated 90 deg from straight, and you rock the frame if you feel anything that is the headset.
    If you are only feeling the "clunking" when riding then it is probably not the headset.
    'Tis but a scratch
    I would just adjust the headset to eliminate it as the cause. There are several you tube videos that will show you how to check it and adjust it. Its quite easy so its worth the 5 minutes.
    Feb 2006
    Quote Originally Posted by 006_007 View Post
    I tried it, turned the wheel 90 degrees, rocked it hard, it seems fine, nothing loose. When the wheel is straight and use the same power you can feel something loose. Its not the skewer and the wheel is quite new. Thx
    I Tried Them ALL... SuperModerator
    Reputation: Cayenne_Pepa's Avatar
    Could also be loose front brake rotor. Check 'em....
    "This is a male-dominated forum... there will be lots of Testosterone sword-shaming here" ~ Kenfucius
    What kind of fork is on the bike? If the bushing are worn there could be enough play that you could feel a knock.
    Feb 2006
    its a carbon rigid fork
    'Tis but a scratch
    A couple of other things to check:
    1) Make sure your QR skewer is nice and tight.
    2) Check whether you have play in your front hub. To do that you can stand on the side of the front wheel, grab the top of it and try to push back and forth (toward/away from yourself). If that has play you likely need to service the hub.
    Either of these items could be amplified when braking.
    Moderator Moderator
    Brakes can definitely make it feel as if the headset is loose, specially V-brakes that will have a little play in them. If you've made sure nothing is loose and it feels fine when riding, it's likely nothing to worry about.
    Sinister Bikes
    Wraith Bicycles
    Sunday River Mtn Bike Park
    NEMBA
    Wachusett Brewing Co.
    My bike with v-brakes shakes when the rim surface gets dirty. I just scrub the rims real good with 91% rubbing alcohol.
    Killing it with close inspection.
    Reputation: J.B. Weld's Avatar
    I've ridden a lot of carbon forks that shudder like mad under heavy braking. Is this a new problem? New fork?
    Feb 2006
    Do you mean take out the wheel and press/push it front/back againts its sides? i have a bolt axle on it i will try a qr. Thx for the info
    Reputation: dirkdaddy's Avatar
    Just hold bike upright with wheel mounted. use other hand to grab the tire and try to move it from side to side and see if there is any perceptible bearing play at the hub. It should be solid feeling side to side, and roll easily obviously. Your brake pads could be grabby. If you hold brakes tight when standing mounting the bike, see if pushing forward and back produces any wiggle in the stem/upper headset. You can use spare hand to feel for movement its not always easy to see it. Good luck.
    Feb 2006
    Great tips it could be the pads. Didnt think about that
  1. Threaded headset to threadless headset conversion
    By op12389 in forum Bike and Frame discussion
    Last Post: 08-01-2013, 04:20 PM
  2. Replies: 6
    Last Post: 11-19-2012, 04:58 PM
  3. Replies: 7
    Last Post: 06-08-2012, 06:26 AM
  4. Replies: 15
    Last Post: 04-28-2011, 07:02 PM
  5. Replies: 11
    Last Post: 01-11-2011, 06:15 PM
