Results 1 to 11 of 11
Thread: brake advice
    Apr 2013
    brake advice
    So I just got my bike and rode it on trails for the first time and I realized my bike needs a tune up real bad. I love the feeling of doing stuff like that my self but I need some help choosing new pads and a new rotor. I have avid elixir cr brakes on the front,160mm. And tektro v brakes on the rear. I live in the high desert of lovely southern idaho . so it is mostly dry and dusty. Just wondering about what would be good options? I ride a trek fuel 90 BTW.
    Nov 2012
    Go XT. At least 180 on the front.
    A $70 SLX brake on the front from Bluesky with icetech pads is an easy bolt-on. The same ceramic 21mm piston as XT and XTR. This will give plenty of power with your present rotor(clean it and bed in the pads) or get a HS1 off ebay. You'll have very good modulation control. No noise.
    BlueSkyCycling.com - Shimano SLX M666 IceTech Disc Brake w/Adapter
    2012 Avid SRAM HS1 Disc Brake Rotor 160mm 2pcs | eBay
    Reputation: MSU Alum's Avatar
    Do you want new front brakes or do you just need new pads? Is your rotor warped? Do you want to go to the expense of replacing the V brakes in the back with discs?
    Apr 2013
    Just looking for new pads and a rotor for the front. I cannot change to rear disc brakes on the rear due to no mounts. I only have front disc brakes cause I upgraded the fork. I would need a different frame. Just looking for a good rotor and good pads all around. Yes my rotor is starting to warp.
    Fat-tired Roadie
    Nov 2007
    Rotors warp. Is it actually causing a problem? You can true them if you really want to. For myself, as long as my brakes are performing well, the rest is details.
    Sent from my DROID4 using Tapatalk 4
    Apr 2013
    It is starting to rub one of the pads when it goes around and they work great I just want them to perform better
    Apr 2013
    Its all in the hope of better performance
    Fat-tired Roadie
    Nov 2007
    My much less fancy Elixirs modulate well and have the power to lock up my rear wheel or throw me over the bars. So you're going to have to come up with something more specific, because it's hard for me to imagine what "better" might mean.
    B A N N E D
    Quote Originally Posted by boomy169 View Post
    You probably can.
    http://forums.mtbr.com/brake-time/what-avid-adapter-i-need-my-trek-fuel-853926.html
    Total Goober
    As noted above, rotors can be trued/straightened. I'm sure there are tons of how-to videos. You can use an adjustable wrench or buy a tool just for it. If there are no deep grooves in the rotors, I would just true them.
    I've had those same brakes, and replaced the pads with more Avids. I've got some Jagwire pads on other brakes.
    And since they're Avid, but might just be defective.
    Quote Originally Posted by Fuglio View Post
    You guys suck im all bummed now
  1. Brake advice
    By modd1uk in forum Brake Time
    Last Post: 08-06-2013, 11:57 AM
  2. bb7 brake advice?
    By titus in forum General Discussion
    Last Post: 06-06-2013, 08:51 PM
  3. Brake Advice
    By TX_CLG in forum Brake Time
    Last Post: 02-29-2012, 09:18 AM
  4. Looking for some brake advice
    By caad4rep in forum Brake Time
    Last Post: 09-12-2011, 06:31 PM
  5. Brake Advice
    By AyeNeil in forum Beginner's Corner
    Last Post: 03-29-2011, 11:04 AM
