Results 1 to 3 of 3
    Aug 2010
    Bottom bracket bearings getting dirty too quickly
    I have a FSA PF30 to a 24mm adapter for my Shimano Hallowtech II XT crankset. I just installed new bearings and after only two rides, one of them a bit muddy, they are full of sand again. I think is the cover the FSA has for the bearings, I don't think is a good system.
    I don't want to have to be taking the bearing out every month to clean them. You guys have any suggestions on what PF30 with a 24mm adapter to use? I'm leaning towards the Praxis Works but do you have any suggestions on how to keep the bottom bracket bearings clean?
    Thank you
    Damian
    Are you getting water inside the frame? Possibly when you wash the bike?
    Aug 2010
    I don't think is water getting in the frame, before even watching it fully, after only two rides, the bearing had sand mixed with the grease. Since is a new bearing, not an expensive one but still new, I took it out of the PF30 and cleaned it. Confirmed it had grease mixed with sand which makes no sense. I really think is the bearing cap not doing its job of keeping dirt out. This is the FSA PF30 to 24mm adapter I have.
    MTB M3 ADAPTER - for Alloy MegaExo Cranksets Bottom Bracket
    Damian
  1. Replies: 10
    Last Post: 05-10-2012, 11:46 AM
  2. Washing bike -- Stumpy FSR bearings/bottom bracket protected?
    By weekendthrasher in forum Specialized
    Last Post: 04-25-2012, 11:21 AM
  3. Washing bike -- Stumpy FSR bearings/bottom bracket protected?
    By weekendthrasher in forum General Discussion
    Last Post: 04-20-2012, 06:17 AM
  4. 2009 stumpy bottom bracket bearings
    By jgo47 in forum Specialized
    Last Post: 11-26-2011, 02:03 PM
  5. Need new Bottom Bracket / bearings..am lost
    By AXOP in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-23-2011, 06:34 AM
