Results 1 to 10 of 10
Thread: Bottom Bracket
    Reputation: etboost's Avatar
    New question here. Bottom Bracket
    hey there
    My bottom bracket keeps getting loose.Its sealed cartridge type. I tried to tightened mounting ring on the non gear side with the special tool, but after one ride,there is play in it and big gear ring rubs on the front derailleur. Do i need to use locktight on it or something else?thanx...
    Picture Unrelated
    Reputation: zebrahum's Avatar
    Jun 2005
    Without more information about what BB you have, I'm going to have to take some guesses here. Are we talking about a BB with a lockring? If so you have to loosen the lockring then tighten the BB shell its self before tightening down the lockring. You don't want to crank down all the way, just enough to stop the crank from having any play in the bearings.
    I'd recommend taking the BB completely apart (no matter if I'm right or wrong about what type you have) then giving it a through clean and re-lube. Then put it back together from scratch with all the threads well lubed and all the pieces in the right place.
    Fat-tired Roadie
    Nov 2007
    Didn't you have a previous post with this problem? Schwinn something-or-other?
    no previous post, my bike is 2010 specialized hardrock (see my avatar...; ) ).
    there is no lock rings, just shimano style mounting rings, sealed cartridge.
    Fat-tired Roadie
    Nov 2007
    Broadly, there are two cartridge bottom bracket standards. Square taper and a couple splined standards. What do you have? You can find out by removing a mounting bolt and looking at the spindle. If a bolt's loose anyway, that should be pretty easy. :-P
    Post a picture once you've got the bolt off.
    Picture Unrelated
    Jun 2005
    Quote Originally Posted by etboost View Post
    So we're talking about an external bearing BB? Remove, clean, inspect for damage, re-grease, tighten to proper torque. The proper torque is (I believe) around 400 in-lbs, which isn't a small amount of torque. If you don't get them torqued up properly, they won't stay in place.
    Just out of curiosity, how do you know they're loose? Do they become hand tight?
    Quote Originally Posted by zebrahum View Post
    if i grab pedals and wiggle, I can see mounting rings move on both side. will regrease and re-tighten it tomorrow...
    thanx
    Here's what I did for this problem.
    Before tightening the pinch bolts I put pressure on the assembly clamping it a little tighter with a 6" metal C clamp and two pieces of a paint stick to protect the crank from scratches. Tighten the bolts progressively one after the other in stages.
    Picture Unrelated
    Jun 2005
    thanx
    I still don't understand your issue since there is no such thing as "mounting rings". A picture would be helpful, otherwise, let's refer to the tech docs and see if we can nail down what's actually happening: http://techdocs.shimano.com/media/te...9830708779.pdf
    My guess is that your BB is fine and you're having an issue with the crank fixing system (numbers 1, 3, 4).
    Reputation: J.B. Weld's Avatar
    thanx
    If you have a traditional sealed cartridge bb, like this-
    then you need to make sure the drive side is sufficiently tight before you tighten the non-drive side cup.
  1. Replies: 10
    Last Post: 07-17-2013, 05:26 AM
  2. Bottom bracket help
    By digitalayon in forum Clydesdales/Tall Riders
    Last Post: 07-02-2013, 09:05 PM
  3. Bottom Bracket Help
    By gsheffer in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-02-2013, 04:55 PM
  4. RIP 9 Bottom Bracket
    By bank5 in forum Tooltime
    Last Post: 09-07-2011, 01:57 AM
  5. Bottom Bracket
    By nov0798 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-19-2011, 05:05 AM
