Results 1 to 7 of 7
    White Knuckle Rider
    Reputation: crump582's Avatar
    Bolt size on my stem?
    Not sure where to post this question, but I want to replace the bolts on my stem and am not sure size to get. I know I've switched them between stems before so I assume they are all the same basic size.
    They have a lot of sizes/ colors here... but not sure what I need, or if there is a better place to get them.
    http://www.torontocycles.com/Selling...num_Bolts.html
    Mods... if this is in the wrong section please move it.
    EAT, DRINK, AND BE MERRY... FOR TOMORROW WE DIE.
    Picture Unrelated
    Reputation: zebrahum's Avatar
    Jun 2005
    Depends on your stem, which bolts you're talking about, and how long everything is. Things I can tell you for sure: they're metric, and aluminum bolts are a third as strong as steel with a lower fatigue life. Not exactly what I would be looking for in a stem bolt.
    If you're talking the headset preload bolt, well that doesn't see much force so I can't say there's anything wrong with getting one of those in Al; I think those are M6x30 typically. I guess it depends on your star nut.
    Take one of your existing bolts to a hardware store. You can find the thread size by trying different nuts. Measure the length and then you have it.
    HatrickPatrick
    I ordered a custom top cap from Purely Custom and the length of the headset bolt they gave me is too short by about 1/2 an inch. Unfortunately the top cap uses a flat head bolt, so my original bolt (which is actually rusting on the inside) is sticking up out of it - horribly ugly. Any one have any ideas on where to track down a flathead top cap bolt (allen socket)?
    Picture Unrelated
    Jun 2005
    Quote Originally Posted by hatrickpatrick View Post
    I would start at the local hardware store. Sounds to me like your starnut is too low. You could always knock that one out and press a new one in.
    gran jefe
    fastenal or mcmaster-carr are go-to sources for bolts/screws/etc.
    Quote Originally Posted by Bill in Houston View Post
    This
  1. Hope bolt-on rear hub bolt size?
    By adept1 in forum Wheels and Tires
    Last Post: 07-13-2009, 05:54 AM
  2. Boxxer direct mount stem bolt size
    By konak in forum Shocks and Suspension
    Last Post: 03-11-2009, 06:52 AM
  3. Ti Stem Bolt For Quill Stem OK?
    By simplton in forum Weight Weenies
    Last Post: 12-11-2008, 01:35 PM
  4. Stem bolt size...
    By JAL67 in forum General Discussion
    Last Post: 05-02-2008, 10:02 PM
  5. 2 bolt stem or 4 bolt?
    By ironbike1 in forum General Discussion
    Last Post: 07-13-2006, 10:00 AM
Members who have read this thread: 10
