• 11-18-2012
    bikeman1
    Bike upgrade - New Frame/New fork
    So after cracking my RST Gila fork (left arch snapped) I've decided to upgrade to something a bit better.
    My current frame is an Apollo Ascent 2008 model (http://goo.gl/E3z0a) in small.
    I found this Rockshox Tora 302 U-Turn. (RockShox Tora 302 | Trade Me) Due to that fork being 130mm max travel, my current frame could get damaged because the current fork is 100mm.
    I could pickup a GT Chucker 1.0 (2005) Frame for $55 (GT Chucker 1.0 Frame (Medium) | Trade Me), then transfer everything over to the Chucker frame.
    Will this combination work well? Will the steerer tube need to be cut? What about the headset/bearings?
    I guess I could just shorten the travel on the fork to 100mm-120mm and just use my current frame.
    I will use it for mostly cross country, and *some* downhill.
    Specs: Apollo Ascent 2008 frame, Avid BB5 brakes, XT shifters, LX rear der, RST Gila(broken), Truvativ cranks, Alex Ace 17 rims, Easton bars, Cane Creek headset.
  • 11-18-2012
    AndrwSwitch
    Weird spec. They don't give you much of a fork.
    I'd just throw the Tora in there. People go +/- 20 mm pretty frequently. You're doing more than that, but you also have the U-turn knob.
    I think you'll run into funky handling before you actually damage the head tube. And if you do, you can look for a new frame then.
    I don't know the answer to your compatibility questions. Or rather, I'm pretty sure you're fine for head tube diameter/steerer diameter/headset. But the seller doesn't say anything about how long the fork's steerer tube is and neither do you. So it would be good to find out how much steerer tube that Tora has, and figure out how much you need it to have.
  • 11-18-2012
    Bataivah
    Yea, alot of forks for sale have too short of a steerer, so it's useless. Check your old forks to see the min. length you need before you buy a set.
    Don't buy them if you don't know the length of it.
  • 11-19-2012
    bikeman1
    The RockShox Tora 302's steerer length is 240mm. I'll have to check my current forks, but it seems like it should be fine.
    I don't think the GT Chucker has a headset installed.. Would I just transfer the headset somehow out of my current frame?
    Thanks for the input!
  • 11-19-2012
    AndrwSwitch
    Headsets have a million different standards lately. If your bike and the GT frame have matching headsets, you can move it over. If they don't, you need a new headset. There are only a few standards for steerer tube diameter, though, so at least that's still not too hard.
    I don't think a frame swap is a good way forward here. In order for that to work, you also need matching seat tube sizing, matching routing and clamp placement for the front derailleur, and matching bottom bracket standards. You're almost guaranteed to run into some extra costs. You're also rolling the dice on frame sizing.
    If you're really worried about the fork, why not just get one that's the spec travel?
    What's "*some* downhill?" Do you mean shuttle days, or just that you like it when trails go back down the mountain?
  • 11-19-2012
    bikeman1
    I'll probably just get the forks then, if I get a decent price. I'll ride them at 120mm.
    By some downhill I mean just taking the shuttle up.
  • 11-19-2012
    bikeman1
    Just checked the steerer of my forks ; they are 185mm. The Tora are 240mm, so would I just use some spacers or would I just get it cut off?
  • 11-19-2012
    DavyRay
    If you keep the stem you have now, and if you don't want another 55mm of height adjustability, cut it off. I would likely cut it down some. Make sure you have assembled everything before marking to cut the excess off. It is hard to add it back.:)
  • 11-20-2012
    bikeman1
    Thanks. Another question, At what height should the handle bars be placed once I've got the new forks installed?
  • 11-20-2012
    kjlued
    Steerer tubes don't have to be cut, spacers can be added in at the top of the stem if the are too long.
    Depends on where you are comfortable with them.
    BTW, never post your auction finds. ;)
  • 11-20-2012
    bikeman1
    Are the Rockshox Recon Sliver TK's better than the Rockshox Tora 302's? Recon's have 100mm travel and are air forks.
  • 11-20-2012
    Bataivah
    I like air personally, and are lighter. So I like the Recon. With the stem, I normally cut my forks with 40mm spacers added to the stem (20mm/10mm/10mm) so I can always have the option to adjust them up or down. If you cut to stem length thats all you got and your
    stuck with only that hieght.
  • 11-20-2012
    shibiwan
    This may be common sense but remember to add an additional 40mm on top of the combined height of the spacers to fit the average stem. :P
    -S
  • 11-20-2012
    Bataivah
    I toss on all the spacers and the stem, then mark it. I tried the caliper way of doing it, and it was a waste of time. But yea, it seems most stems are also 40 mm tall if you want to go the caliper route.
  • 11-20-2012
    shibiwan
    Make sure it's the Recon Silver TK Single Air before you buy it. The Tora is fine but is a little bit heavier.
    -S
  • 11-20-2012
    bikeman1
    Yep, it is. Lol I didn't realize solo and single were the same :D
  • 11-20-2012
    AndrwSwitch
    Read some reviews on the damping systems before you spend your money.
    Last time I researched it, I decided I'd want to go with the Recon Gold. It comes out of the box with a much better-regarded and more tunable damper.
  • 11-20-2012
    Bataivah
    Both Recons are better than Tora for sure. Depends whats on sale if you like a bargain, or if money
    grows on trees just get a Reba/Sidd etc. or Fox
  • 11-20-2012
    shibiwan
    I believe it is a budgetary issue for the OP at this point.... :P
  • 11-20-2012
    bikeman1
    Haha, yep, I'll try and get a deal on the Tora's tomorrow, if not, I'll get the Recon's.
    What do you guys think is a good offer for the Tora 302's? - just been serviced, seals dampers replaced.
    And what about the Recon Silver TK Air Solos? - had about 6 hours use.
    Thanks for the input :)
  • 11-20-2012
    bikeman1
    :( OH DAMN! The Recon was sold for $200NZ. Oh well. I'll try get the Tora's i guess.
  • 11-20-2012
    shibiwan
    Wait till thursday...er... friday... (or is it saturday for you guys) and pick it up from a thanksgiving sale in the states?
    -S
  • 11-20-2012
    bikeman1
    Could do, would be expensive shipping I guess.
  • 11-22-2012
    bikeman1
    Unfortunately I didn't win the auction on the Tora's. Oh well.. What do you guys think of the Rockshox XC30? Will it be better than my RST Gila RL's (2007). How do they compare to Recon/Tora?
    Wiggle | RockShox XC30 Turnkey Coil 100mm Suspension Fork - 2012 | Forks
  • 11-25-2012
    AndrwSwitch
    Probably better than what you've got, IMO still a waste of your time.
    Historically, at least, the Turnkey damper was a plastic thing that could be damaged a lot more easily than the Motion Control damper, which is the one in their more serious forks. You need to research it yourself, of course, but my understanding was that this will drop into any of the 32 mm stanchion forks, and not something smaller, like the XC30.
    Even if going straight to the fork with the "real" damper is too expensive for now, you can future-proof yourself a bit by making sure to buy a fork that will accept it if you kill the Turnkey (or whatever) damper.
    Another thing to think about is just sticking a rigid fork on there and calling it a day.
  • 11-25-2012
    bikeman1
    Hmm, I just can't really find anything for around $200 thats decent. The closest is the XC30 fork. My mate just got a new bike - 2007 specialized stumpjumper - the forks are Fox Talas 32's. Those are the best forks I've ridden, so much smoother than my RST's and other Suntour XCM's I've ridden.. Is it even possible to get something similar to those forks for a $200ish budget?
  • 11-25-2012
    bikeman1
    Also I've found something 'weird' with my forks.. Even though the travel is 100mm - says on the fork itself, when measured with a ruler, it comes to about 136mm travel. Does this mean I've (in theory) been riding on a 135mm fork even though the travel is only 100mm? So I could just put a 130mm fork on there and be fine with it..
  • 11-25-2012
    AndrwSwitch
    Not at retail. Probably not used, either. Fox forks are very well regarded, and seem to EBay for a lot, maybe more like $400ish.
    Your travel measurement - what did you actually measure to arrive at it?
  • 11-25-2012
    Bataivah
    Marzocchi Marathon LR for $190 at Bluesky.
    Solo Air and 100mm (80mm/120mm) with spacer adjust.
  • 11-25-2012
    shibiwan
    I just picked this up for $400....probably doesn't fit for OP but not a bad deal nonetheless.
    Rockshox Revelation XX WC Da Fork 2011 > Components > Forks > Suspension Forks | Jenson USA Online Bike Shop
    It'll mean I'll have to make an adaptor to fit the tapered fork on my bike.
  • 11-25-2012
    Bataivah
    Yea, most for $200 usually have the steerer cut too short : (
  • 11-25-2012
    Bataivah
    That's a a sweet fork for sure! I'm thinking the steerer is Aluminium and not carbon?
    Like they misprinted the specs maybe? Idk though.
  • 11-25-2012
    shibiwan
    All RS WC (World champ) versions of forks come with carbon steerer and crown. Pretty decent deal either way. Lets see what arrives in the mail. :)
    ....would have been better with a 15QR but that's $200 more.
