Results 1 to 47 of 47
    Bike storage solutions
    What are people using out there? I need to get organized. We have 3 adult mountain bikes, one a carbon frame, all with disc brakes (2 hydraulic, 1 mechanical), a road bike, and two kids mountain bikes with caliper brakes.
    I don't like the idea of hanging bikes by the front wheel, I don't think it's good for them, and can screw up hydraulic disc brakes. Alot of floor stands seem like they wouldn't work well with disc brakes.
    I can't think of a solution, but am banking on the creativity of others.
    Reputation: watts888's Avatar
    Oct 2012
    Either roof or floor. Put the one's you don't use very often on the roof racks. A simple hook/pully system would be the best for the roof. Bike stands for the floor are available with space for discs, especially if you make it yourself. It sounds like you have a lot of bikes, so a blanket "use this brand/style" won't work.
    I made a custom floor rack that can hold 2 bikes and I can use it as a work-stand. Just 2x4s with a 4x4 as the center beam.
    Reputation: lotusdriver's Avatar
    Sep 2013
    I built a wall mount in the garage for my bikes, from pieces of 1" x 1" wood. It supports the bike under the top tube and under the chain stays. I used old inner tube over the wood to prevent any scratches on the frame.
    The mounts are easy to make, just a piece of 1" x 1" wood as a mount, with a bracing piece at 45 degrees underneath to support it. Two needed for one bike. Held on to wall with metal brackets.
    Oct 2007
    hmmmmm
    I use j-hooks, $1 or less per bike.
    Sep 2013
    I don't see either, how hanging a bike by the front wheel could affect disc brakes in any way.
    Reputation: Shakester's Avatar
    Jun 2012
    I use the LeHigh Crawford flip up storage rack that works pretty well. The only minus is, that I had to use concrete screws to mount them onto my wall in my garage, but they work pretty well for the price.
    Amazon.com: LeHigh Crawford Flip Up Storage Rack #FSR13: Home Improvement
    Reputation: Nakedbabytoes's Avatar
    Hang them up from the back wheel instead? I always hang ours from the back wheels as I think that weight on the fork/headset can't be good for a bike hanging by the front tire. Never occurred to me brakes might be an issue. I have brakes of all kinds hanging up. J hooks into ceiling beams work for us.
    I don't hang up my heavy bikes though(Pugsley & cargo bike) mainly because I can't lift them up there!
    2014 Big Dummy
    2015 Salsa Beargrease Carbon 1
    2015 Ice Cream Truck
    Interplanetary Poultry
    Reputation: scatterbrained's Avatar
    Quote Originally Posted by betheriver View Post
    Your hydraulic brakes aren't going to be hurt by hanging the bike from a hook. I've used j hooks in the walls in the garage as well as vertical poles that hold two bikes. Right now I've got one of these in the dine in kitchen area by the back door:
    XPORT Off the Wall Storage Rack - Indoor Storage
    You can get bike hoists for $20 or so any day of the week if you don't mind them hanging from the ceiling (not everyone has the ceiling height to do that). J hooks along the garage wall are going to be the most space efficient as you can alternate front and back wheels to get the bikes close together, placing the hooks high enough that you can store things along the wall under the bikes.
    Editor In Chief, "Internet Tough Guy Magazine"
    "Home of Chuck Norris' Keyboard"
    Nakedbabytoes: is the weight that isn't o.k. for the front of the bike somehow okay for the rear hub?
    Bear in mind that you're putting far more force into the front end just by hitting the brakes than what the weight of the bike will exert via gravity.
    No, not the hub on the wheel but the head tube junction & headset itself having the whole bike's weight at a weird angle instead of straight down. It kindof makes a pivot point and usually at the pivot contains the most stress being applied. I wasn't comfortable with that stressor vs when the rear wheel hangs it straight downward instead, directly from an area(rear dropout) which is meant to handle that weight and stress.
    Just my comfort level and explanation of why front vs rear. I never said front wasn't okay. I have and would hang a bike from the front wheel before. Bikes can handle a whole heck of a lot of more stressors than hanging up in a garage
    2014 Big Dummy
    Only if there was Air in the system to begin with and in that case, they needed to be serviced anyway.
    I hang all of mine but the one I use the most, by the front wheel from the ceiling. I keep the other leaned against the wall in a spare bedroom.
    since 4/10/2009
    Reputation: Harold's Avatar
    how many shops hang how many bikes in the back from either the front or back wheel (or alternate them so they can be packed into less space)?
    It honestly doesn't matter. Brakes, stress on the head tube, whatever. J-hooks for cost-effectiveness. I'm going to be installing some in the rafters of the basement in my new house for bike storage.
    Jan 2013
    Quote Originally Posted by lotusdriver View Post
    It can't, I am doing this for years. My disc brakes are fine...
    Mar 2013
    what about carbon wheels and wheel hooks? anyone have any opinions about that?
    Put a mountain biker in a room with 2 bowling balls and we'll break one and lose the other - GelatiCruiser
    Yes, that's fonetic
    Reputation: whoda*huck's Avatar
    Feb 2005
    It's actually better to hang a bike with front suspension from the front wheel (again, there is absolutely zero chance of that adversely affecting the head tube/headset unless you're also using it to do pull ups), as it keeps the seals lubed. As long as you don't use bare metal hooks with sharp edges, carbon rims won't be affected any differently than aluminum ones.
    Sep 2012
    I hang mine on the wall, from the front or rear tire, using a hook and a tray that came with it for the other tire to set in so it doesn't mark up the wall. if your hydraulic brakes have issues or your suspension fork leaks from hanging your bike then you are doing it wrong, bike maintenance that is.
    Moderator Moderator
    Been using J-hooks forever, no issues hanging them from either the front or back wheel.
    May 2012
    My local REI hangs all bikes, not on the sales floor, upside down from both wheels. It looks like they had custom racks with J hooks built for this.
    Reputation: schmed's Avatar
    I hang 10 bikes in my garage from a long piece of pipe hanging about 12" from the ceiling. The bikes hang from the front of the seat, similar to the Feedback A-Frame rack you see at races.
    Schmed
    2001 Turner O2 XC
    2012 IndyFab Planet Cross CX
    2013 Kona Raijin SS
    2016 Scott Big Jon
    Jun 2012
    I use to store my bikes hanging upside down from two J hooks. What I realized is that when you're ready to ride, you'd just need to give the brakes a few pumps since the fluid just runs out of the caliper.
    Yes, that's fonetic
    Feb 2005
    If your fluid "just runs out of the caliper" the system isn't bled properly. It's a closed system full of fluid, so if there's air in the system it will migrate to the highest point. What you're doing is pumping the piston at the lever and moving the air down.
    Oct 2013
    storage solutions
    Well idea of hanging your bikes does not seem good either to me also because it can damage the critical parts. If you are planning for short term storage you have the option of storing it in self storage facilities which offers excellent storage solutions. You can store it on yourself with proper arrangements such as Climate control and fire proof atmosphere. Check your available options which suits perfect for your kind of storage.
    Jun 2012
    I have to agree with the it won't hurt them at all, all the bike shops here hang their bikes, the ones out on display are in an upright rack but for rear shop storage they all hang the bikes. The front bearings take a shit ton more abuse from riding then anything thats going to happen to them just hanging there. For disk brakes as it has been stated are a closed system, no matter the angle they will work unless not properly bled. These bikes are built tough or they wouldn't last out in the real world, hanging isn't going to hurt them.
    Reputation: traffic002's Avatar
    Dec 2008
    Quote Originally Posted by andrewdpapas View Post
    What critical components?
    I've been hanging my bikes upside down for the past 5 years. Currently I have 2 road bikes, 2 mountain bikes, 2 kids bikes and then two more friend's bikes and a frame and a few wheels. So I've run out of room, and I've had to drop the front of each bike and hang from the rear wheel.
    So there is up to 30# resting on the rim with about a 1/3" contact point. So 90psi? Shoot, my tires are pumped up to 110psi on my road bike. Each hub would normally see 15# a piece sitting on the garage floor. I don't think 30# is going to do anything.
    If you have hydro brakes, they should be already bled and no air. So no impact. If you do have problems, then you need to bleed your brakes properly.
    Otherwsie, please specify what actual component will be damaged? And please provide an actual occurance of the damage.
    Just get out and ride!
    Oct 2012
    considering that was that poster's first post, I'd assume someone was searching forums for "storage" and decided to help out us lowly riders who never thought "maybe we should put our bikes, which we use as often as possible, into a storage shed where we'd have to take a couple hours to drive there and get it" brilliant.
    Mar 2013
    Quote Originally Posted by watts888 View Post
    yea, saw that post and i thought it was total spam myself....
    Dec 2008
    So the only thought I would consider whether to hang by front wheel or back wheel is possible water running down the tubes to the headset (if hung by back wheels and put away wet)
    I do an awful lot of wet riding. I typically leave the bike on the floor and let dry. Then clean up and put away. But I've had too many bikes in my garage lately and they needed to be put away wet or dry...so I'm hanging those by the front wheels. If there is any water in the tubes, then hopefully they'll run out the back...
    Oct 2012
    The obvious answer is going to be "don't put them away wet". However, if you must.
    Bikes are designed to get wet. If properly greased, and you're not riding in the ocean (saltwater), I don't think there would be much issue with hanging it from the rear vs. front tire, assuming it's just water and not some silty sandy mess. Just have a drip try under it. Personally, wipe your horse down before putting it in the stable.
    Oct 2013
    How the disc brakes will get affected by hanging the bike by front wheel, i am thinking but couldn't get it right. I think perfect storage will resolve such issues.
    I hang ours by a single wheel -- by the back if it has pogo-stick forks just because it is easier, but from the front if it has hydraulic forks so that the sponge that lubes the upper part of the sliders get a good soaking. No problems with hydraulic disk brakes.
    As for stressing the components, it can hang upside down by the front wheel with all of it's 25 # of weight forever and not get as much stress as hitting one tree root with my fat ass on it
    If I want to store it in the house or hotel room floor, I get one of those foam swim noodles from Wal-Mart. Choose one with a hollow center. Cut off two lengths about the size of your handlebar grips, slit them, and slip them over the grips. Turn the bike upside down. The foam holds the tops of the shifter and brake controls off the floor, protecting both.
    Reputation: chuckeieio's Avatar
    Jun 2013
    A few have mentioned putting their bikes away wet. Your bike won't blow up or anything but it's not great for the chain, brakes, etc.
    Just to share, when I'm putting away a wet bike I aim an oscillating fan at it on high on an hour timer. It'll dry 10 times faster. If I have time I'll visit it a few times in that hour and rotate the pedals and tires. It also speeds up drying your chain if you wanted to oil it before storing.
    GTA
    Ontario
    Jan 2014
    Has anybody used these or something similar? Bought my wife a bike a few weeks ago and need to make room in garage now
    Feedback Sports Velo Cache 2-Bike Rack at REI.com
    Topeak B2 Bike Stand - Free Shipping at REI.com
    Reputation: Bigb2000's Avatar
    May 2013
    PVC rack for about $10. The ones I need to sale hang from hooks on the wall.
    Reputation: mercyNside's Avatar
    Jan 2014
    Went to HomeDepot and picked up this...
    The rail was $10 bucks for a 5 foot section. Plus 8 bucks per hook. Just about $60 bucks for everything.
    Magically Delicious
    Reputation: Cleared2land's Avatar
    Hanging vertical is tougher on the rider than the bike. Damn! You know how he's going to feel tomorrow.
    A bad day of cycling is better than a good day at work
    Work Truck - Dassault Falcon 7X
    Reputation: NylonStringNinja's Avatar
    Jan 2014
    I got one of these to get my bike up off the floor so the front of our truck has enough room to pull all the way forward in our tiny garage. Only $6 it seemed like the cheapest best solution for a single bike at Home Depot.
    Everbilt 50 lb. Heavy Duty Flip-Up Storage Hanger-01195 at The Home Depot
    storage? hooks? hangers?
    whatever are these things?
    road bike is in downstairs bathroom.
    26 mtb is in "cubby" under the stairs. one of these days I'll replace the blown fork and ride it again.
    29'er is in living room, easy access.
    I dont have a garage so I have to make do with what I can.
    space is limited, there is no way I could hang them like mercyNside. mount parallel like NylonString is feasible. Or perhaps I could get a "tool" shed from Lowes etc and store them outside.
    Jan 2014
    Quote Originally Posted by Cleared2land View Post
    That's going to hurt!
    Old fart
    Reputation: hermantile's Avatar
    Jan 2009
    Half my garage is full of bikes, I found an old futon someone dumped and turned that into my own bike rack. Four bolts and some time with a hacksaw and all is well
    Sent from my DROID RAZR using Tapatalk
    fav quote from an ebay auction: "will not make you numb in the taint."
    Jan 2014
    Quote Originally Posted by Whacked View Post
    I would store my 29er in my living room but my fiancÚ would kill me. Hmm.. Now that I'm thinking about it, maybe I could store my fiancÚ in the living room and keep my bike in the bedroom...
    Jan 2014
    Quote Originally Posted by hermantile View Post
    Picture!
    Wrench
    Reputation: FNFAL's Avatar
    Whoever told you that is wrong.
    May 2013
    I've also got this rack I use for the bikes I rarely ride. I loosen the stem and turn the bars to make them more compact. A really strong set-up.
    Sorry, the Husky rack.
    Quote Originally Posted by mercyNside View Post
    LOL!
    Maybe thats why I'm single......
    Reputation: Burt4x4's Avatar
    Feb 2013
    Quote Originally Posted by NylonStringNinja View Post
    I have the same hanger...put mine down low. The back tire sits at ground level. Keeps it tucked to the wall nicely...got all my other bike stuff hanging there too....
    More of a "parking spot" than "storage"
    Ride MORE = Live Longer
    Love Dirt / Hate Pavement
    Reputation: time229er's Avatar
    Oct 2013
    uh oh...here come the reflector police
    2014 Nail Trail 29...
    Feb 2013
    LOL I see thoes shinny spots too...hehehe
  1. Trail Solutions Mountain Bike Trails 201
    By donwatts in forum Trail Building and Advocacy
    Last Post: 11-17-2013, 10:03 PM
  2. Home brewed bike storage solutions - help wanted
    By markj2k4 in forum General Discussion
    Last Post: 08-18-2013, 10:03 AM
  3. Need Bike Solutions
    By MountianbikeG in forum All Mountain
    Last Post: 04-13-2012, 05:26 PM
  4. Replies: 11
    Last Post: 09-08-2011, 10:01 AM
  5. Child bike trailer: Clever solutions, ideas and findings
    By Davidenko in forum Families and Riding with Kids
    Last Post: 03-11-2011, 08:13 AM
