Results 1 to 10 of 10
    Aug 2013
    Bike setup - forks and brakes
    Hey!
    Took delivery of my new Kona 2+2 XC full suspension bike earlier this week. Love the bike, but really not happy with how its been set up. It was delivered to me as the shop it came from was very far away so I couldn't pick it up and make sure everything was set up correct.
    Firstly the shocks have no where near enough pressure in, I dont have a shock pump but i can probably take it in to a local bike shop and have this sorted fairly cheaply.
    My biggest concern is the brakes. I have to pull the levers about half way before i get decent stopping power. I have a Cube Analogue 2011 with hydraulic disc brakes and they are so much more responsive. Literally as soon as i pull them i stop!
    Not the most clued up on bikes, but does this sound like they need bleeding? Obviously not very happy to have to spend money on setup for a brand new bike
    Reputation: mitzikatzi's Avatar
    You need to buy a "shock pump". You need then to adjust, set and check pressures on forks and rear shocks.
    Do your brakes have reach adjustment? Have you advanced the pads?
    AVID Brake Set Up
    Duct tape iz like teh Force. It has a Lite side and a Dark side and it holdz the Universe together.
    Aug 2013
    I think they do have reach adjustment yes, not sure what this does though or how to adjust? I haven't enhanced the pads.
    I have ordered a shock pump, quite expensive! Looks fairly straight forward sorting the shocks out, just these brakes!
    You should check with the shop that you got the bike from ,some bikes come with a shock pump. Go to the brake maker web site ,it should tell you how to set them up.
    Aug 2013
    Sorted my shock issue out, just bought a pump. Been on the website for setting up my breaks and adjusting the reach hasn't done anything. Followed all their steps with no success. Will be really annoyed if I have to have each brake bled already
    Jul 2013
    If the reach has not adjusted the problem and there is too much throw in the lever you probably will have to bleed them They might not have been factory bled properly from the start. Ive had experiences like this with Avid brakes, I gave up on them and now just use Shimano SLX/XT.
    Fat-tired Roadie
    Nov 2007
    I didn't think that was a current model. Closeout?
    Try getting the brakes bled.
    Aug 2013
    Thanks for the replies.
    I sent an email to the shop that built it for me complaining about the set up. This is what they came back with:
    The brakes should not be instant as riding at high speed might cause injuries.
    Are they just fobbing me off? I feel like my old bike brakes provide much better stopping power much quicker. As mentioned, i half to pull these levers fairly hard before i lock the wheels.
    Really disappointed if this is how these brakes should be set up. If the bike was a year old I wouldn't mind taking it to a bike shop to get them sorted, but it's brand new! I will now have to pay 40 to have them put right.
    Reputation: OmaHaq's Avatar
    Jun 2010
    "Instant"... no probably not, but that was a dumb response from the LBS. Everyone likes their bike setup a little differently. I wrench for people independent of LBS because of this kind of dumb crap. Bottom line:
    1. If you want your bike setup how you like it (I don't blame you)... and want it done on the cheap (again, I don't blame you)... DIY. Learn the stuff. It isn't magic or rocket science. Bikes are simple. Trial and error, not much to screw up.
    2. If you want the bike setup FOR you, then prepare to spend some money and go to a reputable wrench. Usually if they work at an LBS, you can talk them into doing your work on the side for $$$XXX.
    Sorry to hear about your troubles. A lot of us wrench and buy stuff online because of your exact situation. A lot of times LBS = terrible customer service.
    Quote Originally Posted by SCO7TY View Post
    - The only thing that keeps me on a bike is happiness.
    Aug 2013
    Based on your reply, I'm going to do it myself! I've managed to set everything up perfectly for myself so far (apart from the brakes).
    I'll look at ordering a bleed kit offline and do a bit of research, hopefully i wont mess this up!
  1. Disc brakes for newbies - XT M785 / 180mm Ice Tech setup
    By Dangerous 29er in forum Brake Time
    Last Post: 07-16-2013, 06:09 AM
  2. Swapping brakes and forks -- any reason not to?
    By bobonker in forum 29er Components
    Last Post: 10-23-2012, 06:10 PM
  3. Formula The One brakes - setup tips?
    By trenchDiggr in forum All Mountain
    Last Post: 10-19-2012, 04:22 PM
  4. I want disc brakes. This is my setup, am i good to go?
    By GiantRev2 in forum Beginner's Corner
    Last Post: 02-09-2012, 09:40 PM
  5. Replies: 2
    Last Post: 08-22-2011, 05:05 AM
