Results 1 to 11 of 11
Thread: bike lock issue
    bike lock issue
    I have an older Kryptonite u-lock...when it is locked, there's a notch in the outer barrel of the lock so that the key fits in. When you unlock it, the key stays in the barrel of the lock and you can't remove it until you re-lock it.
    Someone tampered with my lock at the bike cage at work. My bike is locked up, but the barrel of the lock has been turned a bit so the notch doesn't line up, and I can't get the key to fit in anymore. I have tried using a bic pen to turn the barrel back to fully locked position so that my key will go in, but I only succeeded in shredding the end of the pen.
    Is there any hope of getting this thing off, or do I need to have it cut off?
    Honestly save your time and cut her off
    Use a flat-bladed screwdriver perhaps?
    You got your money's-worth out of that lock
    Yeah, had the same thing happen to me, use a car jack to bust that thing open if you can fit it in. Good luck man it can be a real beeze to get off.
    I like bikes.
    Reputation: Dirtydogg's Avatar
    I have the standard cable type. Made by MasterLock and the key comes out even when in unlatched position.
    I wouldnt like the idea of the key needing to be in when unlocked for fear of the key breaking off inside. Maybe there would be no reason to leave it unlatched..I don't know?
    I'd spray some lube in there and try to use a mechanics pickset if I was you. They are fine pointed and are very durable. If that's a no-go, cut it off.
    You probably already have done something at this point. Let us know what you ended up doing. Thanks
    Karakoram...ZS44, X-Fusion, Freq i23, Tioga's, Shadow & XT,Shim Hydro 180/160, MG-1 pedals & more.
    Feb 2012
    i'd try using something more durable than a pen if possible, screwdriver suggestion sounds like a good one... good luck though sounds like a tough task
    Stiff yet compliant
    Reputation: Moustache rider's Avatar
    Happened to me once. I just filed off the tab on the key that goes through the notch.
    since 4/10/2009
    Reputation: Harold's Avatar
    Quote Originally Posted by portlander View Post
    destroy that lock to get it off if you have to. those things were recalled by Kryptonite not long after the original bic pen video came out years ago. I was working at a shop back then and do not fondly remember boxing up our remaining stock of Kryptonite locks and waiting for the replacements to come in.
    Well, I spent some additional time trying to get it off with various pens. No luck at all. Called building maintenance and they tried a bolt-cutter - didn't even scratch the thing. They came back later with a grinder and were able to cut through it with that - still took a couple of minutes and was load as h***.
    Makes me wonder how a bike thief can get these off in broad daylight!
    car jack works.
    Picture Unrelated
    Reputation: zebrahum's Avatar
    Jun 2005
    Same way they got yours off; you'd be shocked at the things people on the street ignore.
