Results 1 to 32 of 32
    Bike, helmet, hydration, gloves. Good to go?
    Hey, I'm a MTB newb. I ordered a Rockhopper 2011 last week. Should be here in the next day or so. I picked up a helmet, hydration pack and gloves this weekend.
    Any other gear I really need? Or should I just go for a ride or two and figure it out?
    I haven't been on a bike in 15 years but I used to ride my bmx style bike on an off road my entire childhood. Plus I'm a good athlete so I think I'll have few issues. I plan to wear my regular sneakers and non-mtb clothes at first.
    Made in Canada
    Reputation: tpm7's Avatar
    There's a bunch of threads and I believe a Sticky on this too, but you should also consider carrying at minimum:
    -a multi-tool
    -a mini pump
    -a spare tube
    -tire levers
    If you don't want to carry a spare tube a patch kit will also work. Other than that you should be good to go! Enjoy it! A good pair of sunglasses is also good to have, but not required. You can carry much more, but that is what I would recommend adding to your equipment!
    STOLEN: '07 Banshee Viento - See Eastern Canada Forum for Pictures. If anyone sees it contact me ASAP!
    ^this stuff, but I always definitely carry a spare tube, easier to mess with than a patch on the trail. I then patch the flatted tube at home.
    In addition, there would be other stuff I'd recommend, but I only added the stuff as I found I needed it. So my list would consist of what tpm7 said, plus:
    -chain tool
    -chain quick-link
    -derailleur hanger
    ...but again that stuff isn't needed right away. It really all depends on how and where you ride. But almost everyone benefits from flat tire tools.
    KC Weekend Warrior
    Reputation: the.rebot's Avatar
    Jun 2010
    +1 for all these items. If you don't need them maybe another rider will - that's good trail karma.
    '12 Giant Trance X1, Mavic Crossride Wheels, StansTubeless, SPD Pedals
    Made in Canada
    Quote Originally Posted by XJaredX View Post
    -chain tool
    -chain quick-link
    -derailleur hanger
    Very good idea to have the above as well. If you don't have a hanger or need to buy one a good substitute until you get one is to just carry a quick-link and chain breaker, then, providing your rear derailleur breaks off or hanger bends you can remove your RD and shorten your chain and run the rest of the day single speed.
    for trails where it's very shady, i found sunglasses too dark. I recommend clear cheap home depot safety glasses. They look like sunglasses and I think 3 bucks? That'll save you from taking a branch in the eye.
    edit: also, a small hand sanitizer or neosporin spray and some bandaids dont take up much room and come in handy. small LED flashlight couldnt hurt and they are so small and weigh nothing these days.
    Reputation: fireball_jones's Avatar
    Quote Originally Posted by Jobuu View Post
    You can also get sunglasses with replaceable lenses. I pick up a pair of closeout Smith's every once in a while just to get a set that has a clear and dark lenses.
    What I take depends on how far I'm going. Short loops, I usually don't take the tube or pump. Long, out in the woods rides... some band-aids or first aid is a good idea. As are zip ties. And lights. And maybe a knife.
    Reputation: KEITH21's Avatar
    ... and if we just ...
    Quote Originally Posted by level4 View Post
    You will want some bike shorts, especially after your first ride. I carry a multi tool, allen wrenches, spare tube, and small pump in the truck.
    Thanks for the great feedback. Sorry if I asked a question covered in the stickies. I posted from my phone so it's harder to navigate and read everything. I was looking for the bare minimum to carry. I'm already in over $800 so I was looking to add stuff over time, but fairly cheap stuff I can add now.
    I think picking up a spare tube will be my first thing. I have a mini pump and I have dark Oakley's and actually those clear HD glasses for yardwork too (good idea on those).
    I probably wouldn't know what to do to fix my chain even if I had the right tools (which I'll look up). How often do chains break? I thought it was uncommon unless you are doing very technical trails or shifting when chain is stressed. I'll be on intermediate in central NJ for the near term.
    I've been riding since late last year. I ride 2 to 4 times a week and i have never seen anyone break a chain. (Mostly flats)
    Reputation: Urbansniper's Avatar
    my friend had a flat yesterday...spare tube in my camel bak helped
    I was riding with my friend a couple days back, both of us pretty new to riding, when we meet up with a couple older guys. We rode with them for a while when one of them got a flat. None of us had a patch kit or tubes... Luckily we werent far from the trail head. Me and my friend parted ways and finished the trail. By the time we were leaving the both showed up pushing their bikes with a flat tire each.
    Spare tube(s) are a good idea.
    Professional Speed Bump
    Reputation: captainjoon's Avatar
    Quote Originally Posted by KEITH21 View Post
    I've broken 4 chains in the last 3 years, and also helped out several strangers with broken chain with Powerlinks.
    It doesn't happen often but it does happen on certain types of terrain.
    local trails rider
    Reputation: perttime's Avatar
    Aug 2005
    Fixing a flat is the most common repair you may need to do. I carry a tube AND a patch kit, just in case. After that... you have a crash, nothing's broken but your bar and brake levers are pointing in all sorts of wrong directions. A multitool, or suitable hex keys will fix those. (not overtightening some things may avoid breakage when the parts can move instead of cracking)
    I've broken a chain twice. Both were bad joints: one by me, one by LBS. Others have managed it by shifting under too much load.
    "it IS possible that you are faster or slower than anybody else who is having at least as much if not more or less fun"
    B42
    B42 is offline
    Reputation: B42's Avatar
    Oct 2010
    Quote Originally Posted by the.rebot View Post
    My friends joke about how I never need my own stuff, but people on the trail or friends do. I keep a few granola bars in my pack. Everyone loves it when I pull out snacks at the top of a trail on a long ride.
    Reputation: sgtcurry's Avatar
    Mar 2011
    glasses are essential around where I live. The tree branches and shrubs are close enough on the narrow paths to easily hit your eyes.
    2010 GT Sensor 2.0
    I always bring along a phone. I put it on silent so I can't hear when others call but it is ready to use in case of emergency. No one is gonna disturb me on my ride by trying to call me!
    if you plan to be doing anything steep single track or with jumps I would upgrade to
    1) hard shell elbow
    2) hard shell knee
    3) full face helmet
    4) armored gloves
    5) glasses but preferably goggles
    I like turtles
    Reputation: TiGeo's Avatar
    The knowledge for how to use the tools! Seriously, practice changing a flat at home if you don't know how.
    Geologist by trade...bicycle mechanic (former) by the grace of God!
    2018 Niner RKT 9 RDO - enduro are #@$%
    +1 on the shorts , actually +1 on everything he mentioned above.
    Read the "Mountain Bike Packing List" thread. Thanks to it, I was prepared during my ride this last weekend. I had a thorn puncture halfway into my ride. Thanks to my Topeak Alien II, patch kit, and mini pump I was able to fix it and finish the rest of the trail. First time fixing a flat for me. The practice recommendation is a good one too!
    Jonesin'
    Reputation: ForrestJones's Avatar
    Bike shops will often cut you a deal on accesories when you buy a bike at the same time. 10% off is pretty standard. So you might ass well spend a bit more and get this stuff up front.
    Btw a chain tool/ breaker can also be used to fix a bike that's chain isn't broken but has jumped over a gear and wedged itself between the gear and frame under load. I saved another rider from a long walk with that one.
    Chain lube is good to have too so you can do your own routine maintanence (not that you would take it on a ride).
    Don't let it get you down, but there's a good chance you were an accident.
    2017 SC 5010
    I try to also carry a 5 hour energy extra or a redline energy shot if I'm going on a long ride, helps if you get tired at all, or even before the ride, lasts a while and gives ya a bbig boost and taste better then most gels, at least the texture.
    I also try to get a few extra spokes (make sure you get the right size) and a spoke wrench.
    And mos def. a chain breaker tool and a quick link.
    Rear lights and front if you plan to cycle to your trail location in the early morning. A 3L camel bak helps to store my multi-tool, spare tee and GU power gel. Tire repair kit goes under my seat and foldable pump on my bike frame.
    Reputation: bigfruits's Avatar
    Mar 2011
    needed: helmet, bike, water
    i also wear gloves and carry a minipump, spare tube, small multi tool with chain tool. these are not needed right away but in the semi rare event that you get a flat be prepared to walk the bike out. if you ride with someone with tools and pump, just bring a tube with you.
    That's right, rely on the other guy
    I dunno where some of you ride. Even if I'm just doing a rails to trails ride with my son on my touring bike where I'm barely going a few miles, I will have a tube.
    I don't really want to walk miles just because I don't feel like keeping a tube in the bottom of my pack. All the things I carry add up to mayyyyybe a pound in my pack. It's not a huge deal, really.
    I stupidly didn't have my chain tool & quick link a few weeks ago because I put my pack in the laundry and didn't fill it up with everything afterward, and I had to end a perfectly good ride early because I wasn't thinking and shifted at a stupid time, broke my chain, and had to walk about 3 miles to my car, over rocky, rooty, and hilly singletrack, dragging & portaging a 36 lb. Pugsley. All because I left a tiny link and a tiny tool at home.
    And that likely will be the only time in a year I would use it on myself, but so far this year I've helped two strangers with the chain tool.
    Gotta pay to play
    Reputation: michaelscott's Avatar
    This is what I carry/wear with me when I ride:
    1) helmet
    2) knee pads
    3) 1 gallon of water
    4) 13/14/15/16 mm cone wrenches (double sided)
    5) 15mm Socket wrench (I ride SS)
    6) tire levers
    7) patch kit
    8) 26 and 29 tubes
    9) chain lube
    10) multi tool with chain breaker
    11) multi tool without chain breaker
    12) sunblock
    13) bandages in various shapes and sizes
    14) park tools Gearclean brush
    15) small amount of paper towels in a zip lock baggy
    16) rubber bands/zip ties/ velcro ties
    17) phone with GPS for MyTracks
    18) sunglasses
    For cleaning at home I have a finish line brush cleaning set, citrus degreaser, and a makeshift bike stand. I've got basic tools but haven't really made the jump to bike specific tools yet.
    OK. But what color streamers for the handlebars?
    Gotta pay to play
    Orange.
    Oh- I also forgot the bike bell!
    bring bring!
    I'm A Pedalphile
    Reputation: jonlong's Avatar
    Sep 2004
    Everything listed here is useful, but I wouldn't be in a huge rush to get all those things, especially if you don't feel like buying tons of stuff at once. The things you already got are really all you need to start enjoying the sport. ALWAYS bring a cellphone. Bike-specific clothing will make you more comfortable, but no need to rush out and get it. Tools and spare parts are useful, but only if you know how to use them.
    Bikes:
    Mountain: Santa Cruz Blur
    Road: Trek Madone 5.2 SL
    Commuter: Sette Reken 1x9
    Quote Originally Posted by jonlong View Post
    Yes, that's the reason I asked. I don't want to drop another $400+ all at once.
    I picked up my bike today - I love it! Also picked up a tire repair kit w/co2 carts and a spare tube. I'll have my phone with me and I'll fill my hydration pack with bandages and stuff I already have. I'll add the other items as I go along. Plus I can wait for deals on some of that stuff.
    Thanks for the feedback all. Can't wait to get out there and show off my orange streamers!
    Reputation: el_burras's Avatar
    Mar 2011
    Padded Shorts, believe me you'll thank me after a 50 mile ride
  1. Gloves and Helmet
    By Mudpuppy23 in forum Beginner's Corner
    Last Post: 06-22-2011, 07:41 AM
  2. Kids gloves and hydration packs.Suggestions?
    By integral in forum Apparel and Protection
    Last Post: 04-22-2010, 03:13 AM
  3. Gloves and Helmet buy
    By rodrjosept in forum Apparel and Protection
    Last Post: 05-30-2009, 06:18 PM
  4. Has anyone seen my Helmet and Gloves?
    By lizzle in forum Apparel and Protection
    Last Post: 05-17-2008, 11:48 AM
  5. Which hydration pack to hold helmet
    By ndinh in forum Apparel and Protection
    Last Post: 11-15-2004, 04:25 PM
