Results 1 to 5 of 5
    Sep 2014
    Bike build - Question 2 - Steerer length
    Another question or more of a "please check my math".
    I have frame with 125mm head tube. The headset stack is 30.3mm. Stem clamp stack is 40mm. That all comes to 195.3mm (~7.7"). So if I were to look for an used fork, I need the steerer tube to be at least 7.7", correct? Or am I missing something?
    R.I.P. DogFriend
    Reputation: jeffj's Avatar
    You might add in another 1/2" or more in case you want to use some spacers under the stem.
    Reputation: 70sSanO's Avatar
    Nov 2013
    I'd have to agree with Jeffj, but not just for spacers, but also because 40mm may not be the height of the stem clamp you use. I've seen them go from 40mm to 50mm (with more stem angle).
    John
    1995 Trek 970 - 80mm Atom Race
    1992 Serotta T-Max - 70mm Z3 Light
    1993 GT All Terra - 46mm Mag 21
    (STOLEN)
    Sep 2014
    Thanks guys. I guess that rules out me buying an used fork. Not many of them still have 8" or longer steerer.
    R.I.P. DogFriend
    They are out there, but you will have to be diligent about making sure that steerer is long enough.
  1. First bike build, Q: steerer tube length
    By AKJ in forum Beginner's Corner
    Last Post: 01-08-2014, 03:52 PM
  2. EMD 9 Axle Length build question.
    By atcilscot in forum 29er Bikes
    Last Post: 07-16-2013, 11:56 AM
  3. Steerer length question
    By 14Stone in forum Niner Bikes
    Last Post: 08-26-2012, 01:52 PM
  4. Figuring Steerer Tube Length for New Build
    By emtnate in forum General Discussion
    Last Post: 03-19-2012, 08:47 PM
  5. Quick question about used fork steerer tube length
    By FatTireGoose in forum General Discussion
    Last Post: 07-31-2011, 06:02 AM
