Results 1 to 11 of 11
    Reputation: TerryHowe's Avatar
    Bike Bag not Ball Sack
    Anyone get a bike bag that is NOT a ball sack? I've tried several and not been happy with any of them:
    Attached Thumbnails Attached Thumbnails Bike Bag not Ball Sack-1128091644a.jpg
    They usually have a strap that holds it up tight up against the rear seat rails.
    Old man on a bike
    Must've installed it using the little head... I can almost see the loop for the supporting strap at the bottom of the pack, er sack.
    PS Have you tried to rig a strap to secure it to the rails in any case?
    suum quique
    Me thinks you need to turn it over and use the straps as intended.
    Doh!
    "Of all the things I've lost,my mind is what I miss the most." Ozzy
    Quote Originally Posted by gmcttr
    Yeh, I installed it upsidedown, but only because it was swinging like a ball sack.
    That was too funny. Ball sack. Ha!
    Nervous Descender
    Reputation: Adirondack Blues's Avatar
    WTF??? I've never seen anyone mount a seat pack like that. small loop around seatpost. Strap over saddle rails and around bag to hold things tight. They all mount basically the same way.
    Check out some of our local hills: CDRC (Capital District Road Climbs)
    i also unicycle
    it should tighten up enough to not swing around when mounted correctly. try again.
    mtbr says you should know: i work in a bike shop.
    bikes & beers (on my blog) http://idontrideenough.blogspot.com/
    Pablo Escobar
    Reputation: Azufa's Avatar
    You must have an older one. They drop after the first year or so.
    zip tie it to the rails so it doesnt flop around.. helps if its installed correctly to begin with.
