Results 1 to 7 of 7
    Best way to move pedals more on the side?
    New bike I'm looking to buy has Trutativ Stylo crankset which has pretty much straight crank arm and the pedals were too close to the bike frame for my taste. It felt like the round bone (don't know the real name) in my right ankle would be very close to hitting the largest chainring so I had to move my heel on the side when spinning the crank from 12 to 6 to make sure the bone wouldn't hit the chainring. On my old bike the crank arm has better shape and it goes about 15mm more to the side/outwards than Stylo. Can I update the crankarms or what should I do?
    How much have you rode the bike? You might be worried for no reason. You could ask the dealer to swap out the cranks . There is a measurement that is used called the Q factor ,its the distance between pedals and bottom bracket some people use pedals with longer or shorter axles to get their feet closer or farther away.
    Reputation: theMeat's Avatar
    Hmm, lower Q factor is usually better/more comfy/more desired. Maybe some longer pedals?
    Once you start changing cranks and bb you can run into chain line and front derailuer reach issues. It's best to do some research or know the outcome of the frame/crankset/bb length, and in your case q factor combo.
    Round and round we go
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by empre View Post
    If your ankle does not hit the crankarm as you pedal, it will not hit the chainring.
    mtbtires.com
    Quote Originally Posted by shiggy View Post
    You say this as if it were an ancient Chinese proverb
    Quote Originally Posted by rangeriderdave View Post
    I've only test driven the bike once. The Q factor of my old bike is 180mm and pedal is 100mm wide. Don't know the measurements of the new bike... have to call the shop and ask.
    It might have been that the ankle was close to hit the crankarm where it connets to the BB. It has been few weeks since I took the test ride so don't remember exactly.
  1. Play of rear wheel (rocks side to side)
    By darnelli in forum Wheels and Tires
    Last Post: 04-19-2012, 09:49 AM
  2. Side to side play Sun Ringle Charger 29er wheelset
    By mastakilla in forum Wheels and Tires
    Last Post: 03-18-2012, 07:02 PM
  3. Side to side play in front shock mount on LTC
    By raycje5 in forum Santa Cruz
    Last Post: 11-02-2011, 04:21 PM
  4. Fox Float RLC Oil Change Damper-Side/Spring-Side Oil Bath Help?
    By zbear in forum Shocks and Suspension
    Last Post: 09-18-2011, 07:06 PM
  5. Replies: 3
    Last Post: 07-21-2011, 08:58 PM
