Results 1 to 16 of 16
    Aug 2013
    Best rims for the money
    Im looking to buy a set of rims because im getting a new frame (which will be all black) My silver rims now will look pretty weird imo. I have seen a few rims under the 30 dollar range but i dont know if they will perform as well. My question is what kind of rims can i get that are under $30 that are still somewhat lightweight and sturdy? Also, how easy are rims to put on? I ride 26 wheels and would like to have 2.2-2.4 tires. Also they MUST be black. Thats the priority.
    Moderator Moderator
    It'll be cheaper for you to buy entire wheels than buy rims and pay to have them laced onto your hubs (probably ~$50 labor per wheel for a build, assuming that you can re-use everything else, which may or may not be the case).
    IMHO, spending a chunk of $$ to replace perfectly good parts just to color match accessories is plain silly. It's mountain biking, not a fashion show fer gawd's sake.
    Sinister Bikes
    Wraith Bicycles
    Sunday River Mtn Bike Park
    NEMBA
    Wachusett Brewing Co.
    Aug 2013
    Quote Originally Posted by slapheadmofo View Post
    I understand it's a little silly but for me, the way the bike looks is half the deal. Why couldn't I put the rim on myself? If I couldn't then I have a friend who most likely could.
    Reputation: breaks911's Avatar
    Aug 2005
    The funkier the better.
    Aug 2013
    Could putting electrical tape or duct tape on the outside of the rims work? My rims right now have black in the middle.
    That would work.
    Or...
    You can take the tire off. Tape the center off with the proper paper tape. Get the spoke/nipple area too. Scuff the silver area, after removing any decals. Use 600 grit or a 3M red scuff pad. Dust with sealer/primer. Two light coats to cover with black with some hardener added if you don't want to clear it.
    Done.
    Apr 2014
    Plastidip in black. Peels right off if you don't like it.
    Aug 2013
    Quote Originally Posted by yzedf View Post
    good suggestion. I never would have thought iof using plastidip. I dont think I want to paint or plastidip my rims though. I would like to ave something more permanent. I have sun rhyno lited right now, what if i were to get another pair of those but ones with black all over. I really do not want to spend more then 75 bucks.
    turtles make me hot
    Reputation: NYrr496's Avatar
    You're not going to get anything decent that cheap and then re lace it. The Rhyno Lites are half decent and they cost more than 25 bucks each.
    When I build wheels for friends and they don't want to spend 90 bucks on a Stan's rim, I go to Sun Ringle Infernos. Pretty good rim, but 49 bucks each. Then, like Slapheadmofo said, 50 bucks to relace em. I'd live with the silver ones til you can do what you want.
    I like turtles
    Aug 2013
    Quote Originally Posted by NYrr496 View Post
    Why would it cost $50 to relace them? Is it not possible to do them at home?
    If you are using the same erd rim it is possible to do it yourself.
    Line up the valve holes and tape the rims together.
    This makes it easy to transfer the spokes. Use new nipples and replace any spokes with damage.
    Moderator Moderator
    Wheelbuilding is a bit of an arcane art form. the previous post wildly oversimplifies it IME. I've been wrenching bikes for 20+ years, and it's still the only thing I pay someone else to do. I'm a big proponent of learning how to work on your own bikeand all, but building wheels is not likely something you're going to want to tangle with. Do a little research on what goes into it and you can decide for yourself, but I'd just ride until your current seet is beat, then buy a set of black ones.
    Sinister Bikes
    Wraith Bicycles
    NEMBA
    R.I.P. DogFriend
    Reputation: jeffj's Avatar
    I build my own wheels, it's not difficult.
    The part I left out was tensioning. Using the same rim and transferring is an excellent opportunity to overcome that feeling of the unknown.
    Do it and look where you will be. Ahead of many.
    Borrow a Park TM-1 Tensioning gauge for tensioning and truing in stages.
    I agree with just using my suggestions as a research beginning point. But do not be put off.
    Necessity is the motivation for many learning opportunities.
    turtles make me hot
    Quote Originally Posted by hc720 View Post
    You absolutely can. I must have missed that part.
    I like turtles
    My little friends
    Reputation: EABiker's Avatar
    To the OP, you do know that the terms, "rims" and "wheels", are not interchangable when talking about bikes, right?
  1. Rims Vuelta Zero-Lite Aluminum Double Wall 26' Rims
    By bklynjames in forum Beginner's Corner
    Last Post: 05-08-2014, 02:50 PM
  2. Actual weight Enve 29 AM rims / Reynolds 29er rims
    By madskatingcow in forum Wheels and Tires
    Last Post: 10-10-2013, 12:51 PM
  3. Replies: 5
    Last Post: 03-04-2013, 08:07 AM
  4. Advice on DH rims,tubes or tubless? which rims
    By Realslowww in forum Wheels and Tires
    Last Post: 06-16-2012, 09:13 AM
  5. Replies: 5
    Last Post: 03-29-2011, 03:02 AM
