Results 1 to 7 of 7
    Dec 2011
    Best re-usable link for a sram PC 1031 chain
    I just read on SRAM that the PowerLock is good for a one-time application only.
    I would like to remove my chain for a better/easier cleaning.
    what options do I have and how many reinstall would they last.
    can someone provide a manufacturer and part number I saw multiple but dont know which one would work.
    Thanks.
    Jan 2009
    I think that "one time use" stuff is BS. but you should use a KMC Missing link if you want something that works better.
    Either the Sram or KMC links will work fine. All the guys I ride with reuse them without any problems.
    Apr 2013
    I find the Sram to be too tight on the 10 speed chains. I can't undo it without a tool. The 9 speed version was tight, but I was still able to undo it with my bare hands. The quickest, easiest, slickest 10 speed link is the Connex link by Wippermann. It is reusable and can be done with my bare hands in a second.
    beater
    Reputation: evasive's Avatar
    Feb 2005
    +1 on the Connex link. They're expensive, but I switched to them after noticing that the KMCs wear faster and cause some chain skipping within a couple weeks. I keep a couple KMCs in my packs as trail band-aids, though. They're cheap, and I can give them away without any heartburn.
    Positively negative
    Quote Originally Posted by mack_turtle View Post
    Seems like Mr. Zinn agrees with you Technical FAQ: MTB front shifting problems, master links, and more - VeloNews.com.
    Reputation: masterofnone's Avatar
    I have reused sram quick links many times without issues, but I frequently replace chains anyway and just use the new ones. That disclaimer is mostly to cta.
    To appreciate the flowers you must also walk among s**t to know the difference
  1. Using SRAM power link on Shimano 10 sp chain
    By eugenemtbing in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-28-2013, 10:11 AM
  2. 10 Speed SRAM chain - reusable quick link
    By Qfactor03 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-13-2012, 10:52 AM
  3. SRAM power link w/ KMC chain?
    By flynbryan19 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-05-2012, 04:24 AM
  4. XTR Chain W/ Sram Master Link
    By mtbmonk in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-22-2011, 10:34 AM
  5. HALF link link needed ,using 9spd sram geared chain
    By zippy895 in forum Singlespeed
    Last Post: 02-05-2011, 08:25 PM
