Results 1 to 2 of 2
    Reputation: Bemiller's Avatar
    Jun 2013
    Best high pressure pump
    I am getting a bike in the mail that is equipped with a Fox DHX Air 4.0 rear shock and Fox Talas 36 R 100-160mm front fork. Would the RockShox High-Pressure Shock Pump be a good pump for these?
    RockShox High-Pressure Shock Pump (300 psi max) : Amazon.com : Sports & Outdoors
    Thanks for your help.
    Picture Unrelated
    Reputation: zebrahum's Avatar
    Jun 2005
    I have one of those, they're fine. No complaints. Better than a Bontrager branded pump I have by a small margin. I guess it's not that hard to be a shock pump in all honesty; it doesn't get used all that much and so long as it works when I need it it's a good buy. You could spend more, but I doubt you'll get much more value.
  1. High Volume Low Pressure Pump
    By dancing james in forum Fat bikes
    Last Post: 11-09-2015, 11:08 PM
  2. high volume/low pressure floor pump
    By thecanoe in forum Fat bikes
    Last Post: 04-08-2013, 06:10 AM
  3. Are There Any Easy to Pump High Pressure Pumps?
    By Yardstick in forum Shocks and Suspension
    Last Post: 12-16-2011, 04:28 PM
  4. Low pressure/high volume pump
    By asmallsol in forum Wheels and Tires
    Last Post: 08-07-2011, 04:38 AM
  5. High pressure pump for tires?
    By malariavalley in forum Wheels and Tires
    Last Post: 01-01-2011, 08:16 PM
