Results 1 to 3 of 3
Thread: Bent Spokes!
    Level 5 Rider!
    Reputation: Desidus's Avatar
    Jun 2013
    Bent Spokes!
    Hey guys the other day I was pulling a trailer and the connector detached during the ride. It has a safety strap but unfortunately it sent the connector into my rear tire. Now I have a bend in the spoke and some other scratched up ones. Just wondering how bad a slight bend in the spokes are...
    You earn 1000 exp!
    You are now lvl 5! (5/100)
    Str +3, Sta +4, MTB Skills +1, Grip +1, Iron Butt +1
    New Item - Broken pedals
    My little friends
    Reputation: EABiker's Avatar
    If only slight; not too bad. Ping the spokes and listen to the tones to make sure one isn't too loose or tight. If you need to replace one, you need to either go to the LBS, or remove the cassette yourself if you have the tool.
    don't think you need cassette tool if spoke is on non drive (left) side. I would just check trueness/true your will (youtube) as this should be part of regular bike maintenance anyway. I use a zip tie on my fark as a reference point.
  1. Bent spokes/rim
    By mrgarbageman in forum 29er Bikes
    Last Post: 06-08-2013, 08:04 PM
  2. rear derailleur bent into spokes
    By otsdj2012 in forum Wheels and Tires
    Last Post: 02-21-2013, 11:18 AM
  3. Replies: 17
    Last Post: 08-28-2011, 12:14 AM
  4. Bent spokes, need help
    By Marko G in forum Wheels and Tires
    Last Post: 08-05-2011, 03:40 PM
  5. Should I be worried? Bent/warped spokes...
    By Ratman in forum Wheels and Tires
    Last Post: 02-19-2011, 12:23 PM
