Results 1 to 34 of 34
    Nov 2013
    Beginner build a SURLY TROLL?
    Ive been biking forever of course, but only got serious 2 years ago. I bought a Novara Safari from REI, and ride everywhere, commute, groceries, etc. I have tools, manuals, and have learned the basics of bicycle mechanics (I do all my own car mechanice)
    I am interested in building a Surly Troll from the frame up. I can buy more manuals, tools, and use youtube. The LBS has a friday evening bike clinic where they help with any problems you bring to them.
    My question is, am I taking on too much to try and build this Surly Troll from the frame up? I am not in a hurry as I have another bike to ride. Part of the reason for wanting to start from frame is to learn mechanics.
    You are going to lace you own wheels too, right?
    That is really the only difficult part. And it is only a little time consuming to figure out the right spoke lengths. Get the TM-1 and you will have a great time.
    Sounds like your lbs is a good resource for any small thing you have a bit of difficulty with.
    You should go forward. The info you gain is worth it.
    Redcoat
    Reputation: Brockwan's Avatar
    Aug 2013
    I learned everything i need to get started off of YouTube, its a great resource and better than reading manuals. picture speaks a thousand words. BE SURE though if you are not 100% you check it out quick. On my first build i screwed up some work a few times by guessing and not being 100%. it can be a costly one too.
    Build from the frame up dude. The appreciation of your bike is so much more and its great riding a bike you built rather than some dude in china.
    Mar 2012
    I'm building a bike from the frame up for my girl. Not ready to build my own wheels yet but the rest is basic. If you are half decent with tools you'll be fine.
    His Hers
    2014 Trek CrossRip 2015 Trek Lexa
    2012 Trek Rumblefish 2013 Sette Reken
    since 4/10/2009
    Reputation: Harold's Avatar
    Building a frame up is great. I recently did my second.
    FYI, the dropout/rear disc tab arrangement on those (namely the slotted disc tab so you can move the caliper when you adjust chain tension) is fiddly. Probably not nearly as bad as the on-one I recently sold especially if built geared with a rear derailleur doing the chain tensioning, but still somewhat fiddly and tedious.
    If there is one thing I have learned from building bikes at a shop and transferring that to building my own bikes is that I am meticulous about my bikes funtioning flawlessly and silently. I will not accept a component or aspect of the bike that is unnecessarily fiddly.
    Nov 2013
    I hadnt planned to lace my own wheels, but Ill look into it. Probably Ill use Rhino lites, as that is what the LBS suggested. They are also a dealer in Surly. Im not sure what 'fiddly' means, but I have an idea. Ill get to that point eventually. I decided on the troll because of 26 in wheels (as opposed to OGRE 29in.). I travel around in Asia every winter, to avoid minus 50 in Alaska. Im in Nepal right now, and headed back to Alaska and the LBS in a few months. Looking foreward to this surly bike project. I come to Asia every winter (More than 20 now) and of course a bike trip is a possibility. I have read many blogs and have settled on a 20 in. troll, with 26 wheels. I have all summer to put it together, one slow step at a time. Yes, I have used youtube so far for all my bike mechanics, and basically dont see how people did it before youtube. But obviously they did. Anyway, doing a lot of dreaming and reading about this project, and looking foreward to dumping some of my hard earned $$$ into it! All of you gave the correct answer: Go ahead and get a frame and figure out how to put it together.
    Fat-tired Roadie
    Nov 2007
    I like parktool.com for clear, well-illustrated instructions for pretty much everything. Have your shop face (and maybe ream or hone) the head tube and face and chase the bottom bracket shell.
    Have fun!
    since 4/10/2009
    By fiddly, I mean you have to fiddle or mess with it a lot.
    Go for it...building a bike from the ground up is fun. Piece of advice, though. Make sure you have a pretty good idea of what your completed build will consist of before you start buying parts. Take into consideration parts compatibility and any specialty tools you'll have to buy (assuming you do the entire build without bike shop help).
    Nov 2013
    Quote Originally Posted by AndrwSwitch View Post
    Have fun!
    I hit on those 'park tool' instructionals, and found them excellent as well. And when possible I get park tools if only so I know it actually works. I saw a video about setting my own head tubes, and although it looks easy in the video I felt it was decieving and I should have the LBS do at least that part for me (If not more) Yes, the bottom bracket as well. Someone also mentioned making sure as I go to make sure nothing is making noise. This makes sense too, once I think of it. Make sure each component is seated correctly and operating smoothly before continuing on to the next phase. I appreciate all comments from experienced bike builders, and also see that once I get going on this project Ill have a wealth of experience to draw from on this forum. Im still planning at this point to buy some stock wheels instead of learning to make it myself--I think that might be beyond my ninja skills. since Im Still In Nepal, the bike project is a while away, but Im gathering as much info and ideas and bookmarking websites as possible before I take the plunge.
    Nov 2013
    Quote Originally Posted by owensjs View Post
    Yes, Im trying to visualize the finished project, what I want it to do, and how it all fits together. Im looking at lots of blogs and see how other people put theirs together, and what their reasoning was for the different components. This is why I was a little apprehensive about this project. But now as I go and find that lots of people have done it it makes sense. Im looking foreward to the learning experience and being able to tell what is wrong with my bike when something doesnt work. That part will be worth it. As I said, Im not in a hurry, and it can take all summer to build if necessary. But I am considering a bike trip in Asia with it next winter. Maybe. (Im in Nepal right now)
    Fat-tired Roadie
    Nov 2007
    Wheels are actually not that hard. They just take patience. Expect to spend around eight hours on your first set, though I highly recommend tackling them in stages. This is both to let the components settle a little better and because I find if I get impatient and start to rush, I don't end up with as good a wheel.
    If I was doing a bike from the ground up, I'd copy-paste a build list from somewhere and fill it in. Then I'd be relatively confident I wouldn't miss something. No guarantee, but that's one of the things having a local shop can really help with.
    Nov 2013
    I looked at Sheldon B's site on wheel building. Ill read more and see if I want to tackle it. One idea I had is to first build a back wheel for my 700cc touring bike (Novara Safari REI) and see how that goes, and see if I want to build the wheels for my surly troll. I tend to carry a lot of weight on the back of that bike (Novara Safari), as well as Im pretty huge, so it might be a good start to see if I can build one for that bike first, just for the learning experience. Then if it doesnt work too well for me im not without a wheel (Havnt put all my eggs in one basket)
    NOTE: I just saw a surly TROLL here in Phokara, Nepal. The guy rode it all the way from London England to Nepal.
    Feb 2013
    Congratulations on deciding to build your next bike instead of buying a complete. It's a rewarding process. You will learn a ton about working on bikes and be a better cyclist for it. Also you end up with a finished bike that is exactly what you want. That said, building up a bike from a frame requires some special tools, and if you aren't a constant tinkerer, it may not be worth it to purchase these tools. Hopefully your LBS will allow you to borrow these tools during their clinic. The main things I'm thinking of are the tools to ream and face your head tube and bottom bracket shell, a headset press, and bottom bracket tools. Outside of these, pretty much all you need is a set of metric allen wrenches, cable cutters, and maybe a torx wrench or two depending on your components. Building from a frame is much more expensive than buying a complete, but you can defray cost by being patient and finding good deals on lightly used or take off parts on E-Bay.
    Best of luck to you on your new project!
    Nov 2013
    Quote Originally Posted by Iamrockandroll13 View Post
    NO, I wasnt intening to do the reaming and pressing at all. Im definatley planning on LBS to do that. I have all the other tools you mentioned, and can pick up other as I need, if they are simple tools. Im only a little bit thinking of lacing my own wheels, probably not, though, just buy some off the shelf.
    Yes, I was surprised that it is going to cost more to build as opposed to buying pre-built. I thought labor cost made it expensive. But a big part of it is learning the process, and understanding it, and having the tools to keep myself going. I have a job and make $$$, so putting a couple hundred extra into the project wont bother me.
    I backpacked around the third world for 20 winters, and kinda lookin' for something new, and maybe biking around Asia and Africa could be a new thrill. Ill want to know what makes my Troll tick, and have the hand tools to get me back on the road.
    Nov 2013
    I am reading mixed reports on reaming the head tube and BB. Especially with the surly, many experienced bike builders do it without facing these. They also set the bearing races themselves. About half the people did, and half didnt.Many of those who didnt were experienced Surly builders or LBS staff. One price quoted was $95 to get this done. I realize I am going to throw some money into this project, but I will try and cut cost where possible. I earn my money by the sweat of my brow, and I also like to escape ant play around in Asia all winter, and so I am averse to throwing away my hard earned $$$.
    Anyway, That is one thing I am trying to figure out, if I need to do that, have those faced at the LBS. I am not going to use it for racing or something. I have a idea of riding it around the world, but in reality Ill probably just end up riding it back and forth to the library.
    Anyway, getting together a picture in my mind as to what is involved in building a Surly Troll.
    Nov 2013
    I clipped this directly from the surly website. They say their frames have been faced at the factory. They say sometimes paint gets in there, and so to use a carpet knife to scrape out any paint.To cover themselves, they also suggest paying for facing to ensure best results.
    This from Surly:
    Since Surly frames are faced prior to painting, it is possible to shave the paint off the head tube and BB shell ends with a carpet knife blade. This usually results in an acceptable result, saving you money, but we still recommend having it done the proper way to ensure longest life from your components.
    Oct 2015
    Hi.
    Ive just got a Surly Troll frameset and after advice on details of Shimano Xt M8000 2 x11.
    Im buying the complete groupset online and it seems each component has a number of types.
    My question is does anyone know of what component fits my Troll frames?
    Nov 2013
    Quote Originally Posted by Muzzag View Post
    Hi.
    Hmmm...I started this thread a few years ago and have since buikt a Ogre (instead of the troll) and an LHT. Poke around and ask questions, but I put several differnt combinations of Shimano drivetrain components on my bikes since then and all the stuff is interchangable. You have to have an 11 speed Rear Deraileur for 11 speed, I think. I put all 9 speeds on my bikes so I can move them back and forth. I dont think its a matter of the "right one for a troll' as such as more making sure the parts play well together.
    The only advice the bike shop gave me when I picked up my Ogre frame is Go Slow!" I offer you the same advice. Go Slow!
    Ask a lot of questions, and also I found out the hard way that sometimes if you buy the parts individually off ebay you actually get a better deal. Maybe someone is overstocked and needs to clear the inventory, or sometimes someone buys a component and doesnt use it and so you get a almost new part real cheap. Definatley get the nonmoving seat post and seat and handlebars and whatnot used off ebay.
    Good luck,,Go Slow!
    Nov 2013
    Also an idea is to buy super cheap parts off ebay and use them until you get the feel of it and decide what you really want. Buying the best hi-quality parts at first may not be the best idea because you dont yet understand all the nuances of putting it together. As soon as you get it all set up you will want it all completly different. Youlle buy the high end 11 speed and decide you need a rohloff or whatever. Building a bike is a great way to begin to understand bikes. Just going through the process of figuring out what drivetrain to get teaches youa lot. There are lots f good internet sites available. Yea, try not to blow too much money at first because youlle likely change it around. Its real easy to end up with a huge stash of different parts--pretty much everyone does. I could get two new frames right now and have almost all the components I need to put them together.
    Hey...thats a great Idea. I need two new frames!
    Oct 2015
    Hi
    I'm building a Troll also,
    Using 2x11 Shimano groupset. Buying it online and I must choose the chain line length , either 48.8 or 51.8mm (crankset)
    My question is ;
    How do you work out what the chain line size?
    I assume the 34-24t front sprocket is the best for hilly country and crank length 170mm ideal over 165mm or 175mm for an 18in frame and 5'10'' size rider.
    Oct 2015
    Also
    In terms of rear derailleur , when purchasing online they have 2_sizes available ( long and medium )
    This is for a 2 x 11 with 34-24t ( I'm assuming that's the best for hilly country)
    How do you work if I should use long or medium?
    Fat-tired Roadie
    Nov 2007
    Shimano's web site is good for stuff like that. Rear derailleurs usually have a capacity both for the largest cog and for the maximum tooth difference listed on their spec.
    The largest cog is pretty self-explanatory.
    Tooth difference is the sum of the difference between smallest and largest chain ring and smallest and largest cog. For example, my old bike has a 22/32/44 crank and a 11-34 cassette. So I need a rear derailleur with a capacity of at least (44 - 22) + (34 - 11) = 45 teeth.
    Shimano's a bit conservative about their ratings so in real life you can often get away with more, especially on a hardtail. But since you're starting from scratch, there's no reason not to just follow their recommendations.
    For the chain line, I only see 48.8 mm listed on Shimano's web site. Can you share a link to the page where you're ordering?
    I don't want to say much about your chain ring selection except "assume makes an ass of u and me" without knowing more about how you're planning to use this bike. Are you going to be mountain biking? Doing a lot of road miles? Is your pedaling technique any good/are you going to be defensive about your crappy pedaling technique?
    Oct 2015
    Hi AndrwSwitch and Forum
    Thanks for the detailed reply,
    The website I'm looking at buying the Shimano 2 x11 groupset is CRC, it has a range of differe t sized component to choose from , so is very confusing for the first time bike builder. Don't want to get it wrong as I'll be exporting to Australia
    I'll be riding mostly x country 70% of the time with the occasional bikepacking .
    I've been riding for 30 years and have a reasonable technique, only ever bikes w front suspension a d 26ers.
    Also, any recommendations for rim brands and hubs.
    Ive been looking at Velocity blunt35 but I've heard they are hard to use with tubeless or WTB scrapers, though they are twice the price of Blunt35.
    Also Hubs, it seems Good evo hubs are all the rage. Any suggestions?
    How do you work out the width of the hubs to use? I'll be looking at putting front suspension on the Troll.
    Cheers
    Fat-tired Roadie
    Nov 2007
    Can you give us an actual link to the page where you're making your selections?
    Fat-tired Roadie
    Nov 2007
    And before we get too far - did you already buy the frame?
    Oct 2015
    Hi AndrwSwitch.and Forum
    Yes I've bought the frame, size 18.
    The link ; just type in the following link and it usually comes up as the 3rd one from the top.
    Chain Reaction Cycles Shimano XT M8000 2 x 11 speed groupset builder
    Cheers
    Fat-tired Roadie
    Nov 2007
    I don't want "usually." Please paste the URL.
    Oct 2015
    Shimano XT M8000 2x11 Speed Groupset Builder | Chain Reaction Cycles
    As requested above is the website link where im looking at buying the 2x11 groupset.
    Having trouble with the correct front derailleur type as they have a number to choose from .
    Also,
    Would you be able to suggest brand \ models etc for the following;
    - Wheelset 650b+ ( looking at aluminium thou if you reckon carbon is better , happy to go that)
    - Hubs
    - front suspension
    - tyres
    Just a reminder im using this bike for 70% cross country riding with the occasional bikepacking trip.
    Looking forward to sorting this build as its been a 1year in researching, saving $$$ .
    Thanks in advance
    turtles make me hot
    Reputation: NYrr496's Avatar
    I have 35mm Velocity Blunts on one of my bikes. I say they're fantastic rims. They set up tubeless with a floor pump, so I'm not sure what kind of trouble people are having with them.
    Have a look at Bike Hub Store's hubs. They're excellent quality, light, easily serviceable and reasonably priced.
    I like turtles
    Fat-tired Roadie
    Nov 2007
    Here's another thread about chainline and the XT crank.
    XT M8000 Cranks. Explain diff btwn 48.8 and 51.8 chainline
    Fat-tired Roadie
    Nov 2007
    For the rear derailleur, it depends on how wide a cassette you want. How wide a cassette do you want? You could also just order the long cage rear derailleur. It might be more than you need, but it will work with anything.
    Fat-tired Roadie
    Nov 2007
    For the front derailleur, you get two options for that frame. I don't like adapters and fiddly bits when I get a choice. So I'd do the M8025 high clamp, dual pull.
    Fat-tired Roadie
    Nov 2007
    Surly describes the Troll as fitting up to a 26x2.75" tire. 650B+ is bigger than that - are you sure that's what you want?
  1. Surly Troll
    By dfltroll in forum Surly
    Last Post: 04-11-2018, 05:35 PM
  2. Non-Surly forks on Troll
    By bikeuphill9 in forum Surly
    Last Post: 10-05-2012, 09:44 PM
  3. Which fork? Surly Instigator VS Surly Troll
    By Bokchoicowboy in forum General Discussion
    Last Post: 09-02-2011, 08:21 PM
  4. Like a surly troll, but cheaper?
    By GrantB in forum Commuting
    Last Post: 08-28-2011, 07:13 PM
  5. Surly Troll...
    By pease in forum Beginner's Corner
    Last Post: 05-01-2011, 09:31 PM
