Results 1 to 8 of 8
    hardcore on the bunnyhill
    Reputation: emvath's Avatar
    bearing vs. bushing
    This isn't really a question of which is better, it's more of what is the difference? Okay, you can quit laughing at me now, but I am quite mechanically stupid (city boy) and don't really know what the difference is between a bushing and a bearing. I have a Giant NRS and I think I read that it has bushings in the rear suspension. Any help or could someone refer me to a good site that explains this kind of junk to me? Thanks!
    Mr.Burns: Quick Smithers, bring me the mind eraser device!
    Smithers: You mean the revolver, sir?
    Mr.Burns: Precisely.
    Reputation: Rickster's Avatar
    Feb 2006
    Generally speaking, a bushing is a soft metal or plastic one piece part designed to keep a harder pin, shaft, or what have you, aligned while allowing free movement. The bushing wears out and is replaced as needed. A bearing is usually a three piece part consisting of an inner race, an outer race, and balls or rollers in between. Properly applied, bearings provide better alignment, less friction, and last longer.
    I'm not broke but you can see the cracks.
    Rick’s Law Of Biking...
    At least two uphills are required for every downhill.
    Truth...
    I work to survive, I play to live.
    Mind, Body, Spirit...,which one is keeping you from getting better?
    Reputation: dcairns's Avatar
    Mar 2006
    Quote Originally Posted by Rickster
    I would have to disagree. Ever see a car suspension with ball bearings? Bushings are more approprate for high impact, low speed joints.
    Actually the reason they're used in cars is that they're cheaper to replace and fulfill the function just fine. Not to mention the fact that the bearings on bikes aren't subjected to the types forces the bushings on a car are subjected to.
    pain don't hurt
    Reputation: TurboasT4's Avatar
    Vaginatarian
    Quote Originally Posted by dcairns
    like a bottom bracket or headset?
    bushings are used on bikes because they're lighter and cheaper than bearings
    ride hard take risks
    Reputation: dogonfr's Avatar
    Jan 2005
    Bushings & needle bearings can handle loads especially laterall loads. Much more stability. A ball bearing allows flex with a laterall load like hard cornering.
    Ever see a formula car with bushings?
