Results 1 to 8 of 8
    Feb 2006
    BB7s vs cheaper hydros
    I replaced my bb7s with a pair of bengal helix 3 hydraulics. I have trouble adjusting the rear caliber as there are no adjustment bolts. Whatever I do I cannot avoid the rotor touching. Its so bad I am thinking to go back on bb7s. Any thoughts? Thx
    There are shims to space the caliper,check your LBS.
    Reputation: UEDan's Avatar
    With hydraulics all you should really need to do is, loosen caliper bolts, clamp down hard on the brake lever and hold, then tighten caliper bolts.
    Reputation: mitzikatzi's Avatar
    Sometimes you need to remove the pads and advance the caliper pistons a little. Clean and lube the pistons with rubber grease. Push then back in with a plastic tire lever. Replace pads. Then center caliper as stated. This is a common with Avid pads. Lots of threads on it.
    Duct tape iz like teh Force. It has a Lite side and a Dark side and it holdz the Universe together.
    Bandit 29 FTW!!!
    Reputation: In-Yo-Grill's Avatar
    Quote Originally Posted by Markleo View Post
    Just curious as to why you switched from the BB7's?
    Let's make like a Bike and get the Huck outta here...
    B42
    B42 is offline
    Reputation: B42's Avatar
    Oct 2010
    Not the OP, but I switched to hydros from cable because I ride in rain and mud a lot. Could never keep the cable clean and the pull strength required would go from light touch to hand cramp in just a few rides. I was tired to replacing cables/sleeves. Don't have to do anything with the hydros.
    ## Every time I cheat death it reinforces the adolescent belief that I'm invincible. ##
    I ride bikes
    Reputation: moefosho's Avatar
    Apr 2013
    Is the angle off or is it rubbing on 1 side?
    Sep 2012
    common with hydro brake calipers if new or installing new pads. pistons have to be reset or pushed back. levers may have been pressed without anything in between the pistons or pistons are all the way out from thin/used-up pads.
  1. BB7s vs helix hydros
    By Markleo in forum Brake Time
    Last Post: 09-09-2013, 07:06 PM
  2. talk me out of it- BB7s to SLX hydros
    By mack_turtle in forum Brake Time
    Last Post: 05-20-2013, 03:30 PM
  3. My cheap hydros
    By Ihitatree in forum Brake Time
    Last Post: 05-11-2012, 05:18 PM
  4. BB7s vs. Hydros?
    By myitch in forum Brake Time
    Last Post: 01-31-2011, 10:50 AM
  5. Promax Hornets Hydros or BB7s?
    By millsj2 in forum Brake Time
    Last Post: 01-26-2011, 08:00 PM
