    BB/Crank Question
    Ok I need a new BB and thought I'd get a new crank set as well. What does ISIS mean?
    I have a Truvativ BB and an FSA Alpha drive crank--both lower end parts but wore out in a year? Crappy of you ask me.
    There's no app for this.
    Reputation: JimC.'s Avatar
    ISIS is the god of
    ISIS bottom bracket spindles feature a 10-flute spline, one-degree tapers and 16mm long splined ends. Increased crank/spindle interface spreads loads over a wider surface area. One-degree tapers provide a creak-free tolerance fit. The stop shoulder design prevents distortion to the crank arm socket from repeated removal/installation. Oversized bolts prevent loosening or creaking. ISIS bottom brackets will only fit ISIS splined cranks.
    Jim
    Reputation: dir-T's Avatar
    If you ride a lot, especially in wet muddy conditions, it's not too uncommon to wear out a bb in a year. But it is a bit quick. Is there actual play in the spindle or is it just making noise? A lot of times you can just remove it, clean and grease the threads, and reinstall and the noise will stop.
    As for the crank, is the crank itself worn out (I've never heard of that happening before) or are the chainrings worn out. You can probably just replace the rings for le$$.
    The BB is` worn. It is not completely dead yet. I had it seviced and the creaking went away but he said it won't hold up too much longer. My crank set is ok. Im looking into the FSA afterburner set because of the sealed bearings. That would help. We have alot of mud here.
