"The Basic Cleaning and Maintenance Guide has been updated and can now be found in the MTBR Pro Review 'How To' section, just follow this link. Please note that comments have been disabled on the guide itself, but please feel free to post your comments and/or criticisms at the end of this thread."
I actually enjoyed this. I am trying to make sure I get everything done right to maintain my bike as long as possible. Just bought my first bike on friday and it has been a pleasurable two days.
this is all great information for everbody. I just purchased the bike and on the second or third ride, I rode in some very extreme conditions with my last bike, crossed several deep streams and afterwords merely washed the bike with water. I witnessed my bike age one year overnight, all because I didn't maintain it properly after the ride. the bike did not shift as well, the brake pads dissolved during the ride. The water trapped in the calipers caused the pistons to fuse by electrolisis into the caliper body.
I had to take the bike in the the shop twice to correct the brakes and get the shifting corrected. They did a complete overhaul, taking out all moving parts to clean and lube them. I hope I learned my lesson.:madman:
Great work. This must've took some time Thanks for the effort.
P.S. "I could have gone into much more detail but felt that I needed to strike a balance of information and keep coverage simple." Are you kidding??? This is the most detailed bike maintenance guide I've ever seen!
Here's a good tip: Kerosene works great as a chain cleaner.
I've been using it for years to clean motorcycle and bicycle chains.
Safe for all bicycle chains and all motorcycle standard roller, o-ring and x-ring chains.
Simply take the chain off of the bicycle, drop it in a container with kerosene, let it soak, swish it around a bit, take it out to inspect it, use a brush on it if needed for any stubborn build up, grab the air compressor hose and blast the chain dry before lubing and reinstalling on the bicycle.
Quick and easy
Chainsaw bar & chain oil or motorcycle standard roller chain spray foam works great on bicycle chains.
very informative i'd say.
just let me add this, for cleaning the engine externally, brush it with kerosene and wipe it dry with a clean rag.
Keep it up,more and more of us are learning from these tips
Just bought my GF Big Sur. Like every other bike I buy or find, I clean and tune, clean and tune! I will check out the link, as I'm sure there is something that will be learned.
well, tires should be worn out before any type of "sun damage" gets to them. and armor all on your seat? er.. no.. methinks that would be a wee bit too slickery.
Good guide, but it should be noted that WD40 and other petro-based lubricants will break down and dissolve most plastics. Not sure if that's an issue here, since the guide suggests that as much of it be removed as possible when done using it, but just something to note.
Related Threads
Mountain Bike Reviews Forum
15.4M posts
515.2K members
Since 1990
