• 03-13-2013
    wink23
    maintenance is very important..
  • 04-08-2013
    zz29er
    awesome guide ! a thousand "thank you"s
  • 05-08-2013
    synodbio
    Appealing information you have provided. It gained me more knowledge and idea. Please keep up the good because i like the way you are writing. Thanks!
  • 07-05-2013
    rshalit
    zzz
  • 07-18-2013
    Island20v
    Good info in there, thanks.
  • 08-27-2013
    Artmor79
    great info, i need to buy me some tools and repack both hubs with new grease.
  • 10-28-2013
    chucklinus
    Very helpful! Thanks for the guide!!!
  • 01-04-2014
    Adam Enggasser
    Definitely some great tips!
  • 01-17-2014
    bruceleader
    Always try to work on your own bike!
    I agree!! Amazing guide!
    I want to make a case for working on your own bike.
    I jotted down some reasons in a recent blog article, you can find it here if you feel like an informational laugh.
    Keep the rubber side down! Cheers!
  • 04-24-2014
    shinge
    Thanks too
  • 04-24-2014
    jamieharris
    Great tips for beginners!
  • 05-12-2014
    adrenalinejoe
    Awesome guide. As a newbie to the mtb world this has made bike tune ups a lot less intimidating. Im glad i stumbled across this before caving to the lbs for help. Thanks for the time and effort spent.
  • 10-28-2014
    orlagallmty
    very explicit guide, thanks !!
  • 07-10-2015
    Codeman
    This is great info. Hopefully it will save me some time and money from always having to take the bike to the LBS for even the smallest adjustments. I'm not really mechanically inclined, but from some helpful advice now I was able to adjust my front derailleur because the chain was not going into little ring. Normally, I would just think that only the LBS can fix something like this, but through some instruction on the website I learned that it was as simple as turning a tiny screw a half turn. Once I did it, the chain easily moved into the little ring. So, its great to have this info to help us. Thanks so much!
  • 07-11-2015
    hendrawan
    Great,very details. Makes me know more about my bike
  • 07-14-2015
    Northstar01
    Nice guide! Thank you!
  • 08-11-2015
    Gorn1120
    It'd be even cooler if you had videos on each part.
  • 08-23-2015
    spyghost
    i've busted my lower headset bearings after 3 months of not so abusive use, but from cleaning after every ride.
    what i think i've done wrong is using a garden hose to wash it (sprinkle). after i've replaced my busted lower bearing, i just use a damp sponge to wipe stuff off.
    according to cc aside from the lower bearing accepting most of the upward force from the fork, water tends to seep from the top and tend to pool on the lower part, hence busting it out easily.
  • 10-10-2015
    Wikiddude
    What can I use for as an alternative for chain oil if I don't have the right stuff with me?
  • 10-11-2015
    ChILd_ReBoRn
    Automotive oul..sae 10w40, or oil for fine mechanics
  • 10-12-2015
    Wikiddude
    My friend just gave me wax, I'm using that for now. That wont gum up the chain will it?
  • 01-16-2016
    amitpokhrel
    great article..
  • 01-31-2016
    fearfeedsmee
    Excellent Guide thank you for putting this together
  • 03-09-2016
    WASHOFSKYC
    Thanks for the help thanks be to god
  • 04-19-2016
    gregzx
    Thank you very much! The guide page has been bookmarked! :)
  • 05-26-2016
    Landocalriz
    Awesome! Thanks for the Tips!
  • 06-07-2016
    snowboardgeek1
    Thank you!
  • 07-01-2016
    Getmeinshape
  • 07-07-2016
    Kharmore
    Thanks a lot!
  • 07-12-2016
    DcDeathscythe
    Very nice, very informative.
  • 07-30-2016
    Blueblazeme
    Much appreciated!
  • 08-05-2016
    Westcoast_kid
    Very helpful.
  • 08-05-2016
    khagan
    excellent guide
  • 08-29-2016
    Usman22152
    Awesome write up
  • 10-16-2016
    TOPFLiTE1994
    No pics
  • 04-14-2017
    kybikeman
    This may be a dumb question, but I'm about to clean my bike for the first time and I'm not sure where break/ derailleur pivots are that I need to drop some lube on. Help appreciated
  • 04-14-2017
    Ratheruneeq1
    Great info! Been looking for something like this!
  • 04-16-2017
    BMArias15
    This was exactly what I needed.. ended up giving my bike as well as 2 other friends bikes a tuneup and wash.. never knew it was such a detailed and required maintenance with these bikes. 👍🏾👍🏾👍🏾
