Page 14 of 26 FirstFirst ... 4 10 11 12 13 14 15 16 17 18 24 ... LastLast
Results 326 to 350 of 630
  1. #326
    Good info, but most of us are not going to do this each time back from the trails. So what does everyone do in the interim? Is a spray down with a hose appropriate to get the mud off?
  2. #327
    Great post! This is an awesome how to guide for a new rider like myself!
  3. #328
    Trail Ninja
    Reputation: Varaxis's Avatar
    Really good guide. I only became more careful with what cleaning agents I use, after getting some more refined experience washing my car and recalling some aircraft cleaning experience.
    There are some motorcycle wash solutions that don't harm waxes, clear coats, greases, lubes, and don't harden/embrittle surfaces like some other cleaning solutions, but they're a bit expensive. Just straight up water and some good brushes and some elbow grease for spot cleaning is the simplest route and is just as effective.
    Stuff I used in the past which I've ceased using:
    Dish soap = unfriendly degreasing action (also strips off protective coatings as well)
    Simple green = unfriendly to materials, hardening/embrittling them; also unfriendly degreasing action
    Other degreasers = used properly, such as for small parts cleaning, it's fine, but it's simply too expensive and requires too much prep and careful handling to use effectively
    I'm using WD-40 for spot cleaning sticky greasy stuff, mainly my drivetrain. It also helps shine up polished metal really well, particularly titanium. I'm using Pledge furniture spray to keep the dust off clear coated surfaces, spraying it onto a cloth and applying it. I bought a bunch of cheap microfiber towels from Meritline that I use to finish the bike and do the real detailed cleaning.
    Takes about 10-20 minutes from a light hose down to really clean the bike. I pull my stand out to the drive way, put the bike in it, and take off the wheels to start. I grab my 20 gal bucket (under $5 from any hardware store) with all my brushes and towels in it and set it near the bike. I use a garden hose with a pistol-grip head to make a wide spray from a good distance, mainly just to get everything wet (wider and lighter than a shower). I hit the dirty spots with a brush to loosen the dirt and work the water through the caked on crud. I then lightly shower it again with the hose to rinse and use 3 or 4 of the microfiber towels to dry it and to wipe all the crud off that the rinse missed; this drying step is the most time consuming, but it ensures everything is clean and also acts as a visual inspection of the bike for cracks and such. I then hit the wheels, using the same process. I then hit the drive train with a smaller drivetrain-specfic brush and a little WD40 to loosen the greasy crud, and a paper towel to wipe it up. I finish by taking a clean cloth or paper towel and buffing the bare/anodized metal surfaces with WD-40 and another cloth for buffing the powder or clear coated surfaces with pledge furniture spray, to help protect it. Seems to work as well as silicone spray/polish, for far cheaper, and much easier/safer to apply (bad news if you spray silicone stuff on something like braking tracks and pads).
    Doing it this way, I know my lubricants are still intact, I'm not harming anything on my bike, and basically everything lasts longer while looking better. Nothing really beats elbow grease when caring for your bike. Solutions that you apply to a towel or brush head first and then are applied to your bike parts are the best way to clean without unintentionally harming other bike parts. I tend to time my bike washes to coincide with whenever I need to lube my chain, though not every time I lube my chain. I can go months between cleanings, depending on the weather and whether I do some water crossings or ride through damp areas.
    Doing it the lazy way for quick 5-10 minute washes, with focused or high pressure water spray, a soapy/cleaner/degreaser solution, and no significant time spent on drying (ex. bouncing your bike or sprinting on the road in front of your home) can leave your bike in a state worse off than if you didn't wash it at all. Your bike parts won't last as long and will show signs of needing to be relubed/overhauled much sooner. You might see a few pro bikes getting washed this way, but also watch if those same bikes suffer from mechanical faults.
  4. #329
    great tips!
  5. #330
    Perfectionist with ADHD!
    Reputation: ChewynMe's Avatar
    Great Tips
    These are great tips for those who have purchased decent bike recently and want to know the best way to clean them!
  6. #331
    Hey guys, i'm new to mountain biking and i just want to ask, can my Crank: Shimano Octalink alloy(44x32x22T), BB: Shimano BB ; be converted into a single speed crank? Thnx
  7. #332
    Reputation: celica90's Avatar
    May 2012
    Great information thanks!
  8. #333
    May 2012
    Great post!! Thanks for the info.
  9. #334
    May 2012
    Good info thanks
  10. #335
    Great guide, this will help me out a lot thanks.
  11. #336
    May 2012
    LBS Rules
    Just bought a couple of used bikes---LBS has been awsome taking care of me even tho i did not buy there. Big UPS!!!!
  12. #337
    May 2012
    thanks for the info
  13. #338
    May 2012
    Thanks for this nice shares.
  14. #339
    May 2012
    thanks for the share
  15. #340
    awesome info thanks
  16. #341
    May 2012
    I was looking for a guide in cleaning thanks
  17. #342
    May 2012
    nice post
  18. #343
    May 2012
    Good info, thanks!
  19. #344
    May 2012
    Nice post
  20. #345
    May 2012
    Nice guide Steve, thanks for posting this up. Newly back into biking and need to learn to do my own maintenance as I live too far from any LBS. This will help alot
  21. #346
    May 2012
    Great info!
  22. #347
    May 2012
    Roger that. All of that.
  23. #348
    May 2012
    Liked the wd40 information
  24. #349
    May 2012
    Wow thank you for the list!!
  25. #350
    Mar 2011
    Nice detailed guides, thanks
