Results 1 to 8 of 8
    Sep 2013
    Avid Elixir 3: How to remove spacer from hydraulic disc brake caliper?
    Hi everyone,
    I'm trying to assemble my MTB and it came with Avid Elixir 3 hydraulic disc brake with a spacer in between the brake pads. I was wondering how I can remove the spacer? Below is the image of the spacer. Thanks!
    Avid Elixir 3: How to remove spacer from hydraulic disc brake caliper?-wfv79gj.jpg
    Attached Thumbnails Attached Thumbnails Avid Elixir 3: How to remove spacer from hydraulic disc brake caliper?-2013-09-13-00.48.27.jpg
    Just pull it out they are handy to have for when you need to take the wheel of and they just push in and pull out
    Sep 2013
    Quote Originally Posted by Hooch View Post
    the spacer is sandwiched in between the brake pads kind of tight, I'm afraid ill break the brake pads or something if I just pull the spacer. Don't I have to loosen the brake pads first or something? I mean if I just pull it out, wouldn't the brake pads come in contact with each other? Ahh maybe I'm just overthinking
    na, just overthinking. brakes are pretty tough and the spacer is wedge shaped so will loosen up straight away.
    Reputation: chuckeieio's Avatar
    Jun 2013
    Excalibur elixir 3
    Avid Elixir 3: How to remove spacer from hydraulic disc brake caliper?-brake.jpeg
    GTA
    Ontario
    ^^^lol
    Sep 2013
    Quote Originally Posted by chuckeieio View Post
    Excalibur elixir 3
    Now removing that Excalibur "Elixir 3" would prove to be the REAL challenge.
    Picture Unrelated
    Reputation: zebrahum's Avatar
    Jun 2005
    Quote Originally Posted by BobaX View Post
    The brake pads only close when you pull the brake lever. The spacer is there during shipping just in case someone pulls a brake lever without the rotor in place. Pull out that spacer and put the wheel on. I keep a spacer around in case I need to store the bike without a wheel on, just stuff it back in between the pads.
  1. Replies: 2
    Last Post: 05-17-2012, 09:29 PM
  2. Remove Piston From Elixir Caliper?
    By LeonD in forum Brake Time
    Last Post: 12-23-2011, 03:04 PM
  3. Avid Elixir CR hydraulic bleeding procedure?....
    By dirtrider7 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-05-2011, 01:27 PM
  4. problem with Avid Elixir CR Hydraulic Disc front
    By dfms2004 in forum Brake Time
    Last Post: 11-05-2011, 07:51 AM
  5. Replies: 0
    Last Post: 07-17-2011, 02:05 PM
