Results 1 to 14 of 14
    Reputation: jhmeathead's Avatar
    Apr 2013
    anyone use this rigid fork?
    Ive been looking for a cheap rigid fork for my hardrock and ran across this
    On-One CroMo 26er MTB Fork
    right length and good price except it doesnt look like they have one for vbrakes in stock. I really like the look of it. Is this the only place to get this fork from and has anyone used it before? I cant seem to find to much info on it
    I know ebay has alum forks that look like this but ive read bad things bout alum forks on here. Carbon is outta the question as i weigh 240lbs. Can anyone point me in the direction to something similar that wont break the bank. thanks
    Quote Originally Posted by jhmeathead View Post
    I can't see the logic of that statement, it's the integrity of the design and construction rather than the material that's important. Carbon is the strongest material you can make a fork out of and there's nothing wrong with Ali either, the bad things you've heard should only put you off that particular fork, not the material used.
    I used to weigh 220+lbs and I rode (and abused) a very light carbon fork for 15 years without a problem.
    Reputation: jetboy23's Avatar
    Quote Originally Posted by Hogdog View Post
    Only because this is a Beginners forum, i want to point out that this is not great advice. Yes, when carbon is built to handle extreme abuse, it can be incredibly strong. Fact is, the majority of carbon forks have weight limits. There is a reason for this. It is possible that a 280lb rider could ride one for the next 10yrs and not have an issue. But, i wouldn't trust it. The front end is the last place i want a failure.
    That said, a Ti and aluminum fork could also fail. Although, they are generally built with a higher durability range. Carbon is usually designed with lightweight in mind. Not burly strength.
    Apr 2013
    I thought carbon forks had weight limits plus the price isnt something i see dropping on a bike only worth a couple hundred.
    Are aluminum forks really that much worse than steel? I ride mostly roads, bike trails, gravel single tracks
    Just Ride
    Reputation: Cormac's Avatar
    Niner carbon fork has no weight limit.
    SS ==> Nut up or Shut up!
    Reputation: Nubster's Avatar
    I've been thinking hard about switching my SS to a rigid fork since I ride with my suspension fork locked out 99% of the time anyways.
    local trails rider
    Reputation: perttime's Avatar
    Aug 2005
    To the original question...
    As far as I know, there is nothing particularly wrong with the On-One steel fork - as long as it is a good length for your bike. Depending on where you are located, shipping and Customs might affect the cost.
    Also take a look at Surly and Salsa steel forks. They don't exactly cost a fortune and lots of people use them too without issues.
    "it IS possible that you are faster or slower than anybody else who is having at least as much if not more or less fun"
    If cost is the main issue then yeah, carbon is probably out of the question but don't be put off for any other reason, a good fork is a good fork regardless of material. Just looking at their website and none of On-One's carbon forks appear to have a weight limit but this is getting sidetracked...Apologies.
    Jan 2009
    if you need a rigid fork for v-brakes, you can't go wrong with Surly. what is the length of the current fork, or what length fork was your frame designed for?
    instigator fork, 100mm
    1x1 fork- 80mm
    B-J
    B-J is offline
    May 2013
    Aluminum forks could seem a bit harsh on the front. If you're on a tight budget get down to your local bike stores and see what they've got in their spares bin - bikes come in to get full suss forks fitted and the old forks get left in the shop. You'd be surprised what you can get for $20
    wyrd bi ful rd
    Reputation: chinaman's Avatar
    Was using this On One steel rigid fork on singletracks for sometime. It is a lot of fun but it gives you a real work-out.
    anyone use this rigid fork?-20070901-yeti-arc-69er-htr-02-800-538-mtbr-forum.jpg
    Apr 2013
    my axle to crown measurement is close to 457mm. do you take 10% off that for sag?
    local trails rider
    Aug 2005
    You take off whatever your real sag is, just sitting on the bike.
    Tie a rubber band, or something, around fork stanchion, touching the lowers. Get on the bike in riding position, maybe ride a little on a smooth surface. See how much the rubber band moved. That is your sag.
    A few mm here or there is nothing to worry about in A to C. An inch can be pretty noticeable.
  1. OPINIONS: Aluminum rigid fork or suspension fork for 9yr old's bike?
    By dragbike in forum Families and Riding with Kids
    Last Post: 05-09-2013, 05:06 AM
  2. Replies: 21
    Last Post: 01-13-2013, 09:06 PM
  3. Replies: 7
    Last Post: 09-30-2012, 04:09 PM
  4. Replies: 5
    Last Post: 11-27-2011, 05:18 PM
  5. Replies: 44
    Last Post: 10-03-2011, 07:48 AM
