Results 1 to 25 of 25
    Any reason to keep the valve caps on?
    I was wondering if I need to keep using the screw on presta valves on my tubes... They seem to be just be something extra to deal with when inflating my tires. What practical purposes do they serve?
    I never use them on prestas, just schraeders. I don't that there is any real use for them on prestas.
    On schraeders, are they helpful to prevent leakage or accidental valve depression?
    No, they just keep contaminants out of the valve. Basically a presta is an "outie" and sheds crap but a shraeder is an "innie" and can collect crap that cause problems.
    Fat-tired Roadie
    Nov 2007
    On a Schrader, the valve caps used to have a secondary seal because the valve is just held closed by a spring, and haven't always been that reliable. So it was really part of the valve. Screwing down the little nut on a Presta valve secures it.
    Even though the covers are not really necessary for the function of the valve, I use them. It keeps a bunch of small mechanical stuff cleaner, and that's generally a no-brainer for me. I suspect it might keep my pump head in better shape too. I use the little security nut on Presta, and have to admit to a little bit of schadenfreude when a friend of mine got a flat because the Presta valve on her tube had gotten worked to a funky enough angle for the seal between the valve and the tube to get damaged.
    On wuss patrol
    Reputation: Glide the Clyde's Avatar
    Quote Originally Posted by Dopaminer_09 View Post
    I think the caps look cool
    Sometimes, you need to go fast enough that the trail is a blur to find clarity. -- Wild Bill
    that guy
    Their primary function on presta valves is to keep them clean. To me, that makes them worth the extra 2 seconds it takes to remove them...
    Makes sense to use them. Just a little annoying when, 1 minute later when I am done pumping up the tire, I can't figure out what I did with the cap!
    Quote Originally Posted by paleh0rse View Post
    Reputation: TheMTbiker89's Avatar
    I keep my caps on because mud and debri can get in it and mess with it. I also find it annoying trying to find the little caps, but now whenever I'm putting air into my tires I just put the caps in my pockets or I keep them in my hands until I'm done.
    Sent from my Droid
    Never take life seriously. Nobody gets out alive anyway.
    SSolo, on your left!
    Quote Originally Posted by jlmuncie View Post
    I used to think this until the very tip of my prestas (the little part that screws down to hold it closed) got bent by sticks and/or rocks that flew through my spokes during rides. I noticed that they were bent while airing up my tires and carefuly bent them back. Checked and they are not leaking. Always use the caps now.
    Get off the couch and ride!
    T.W.O.
    Reputation: mimi1885's Avatar
    Quote Originally Posted by Natedogz View Post
    Well put
    I hate change the presta's gut. It's so easy to break too if it get hit at speed. I'm running Tubeless so it's a no brainer to me to keep them protected.
    Reputation: monzie's Avatar
    I use them to take up space in my trash bin.
    Quote Originally Posted by Tone's View Post
    Id scrap the passion forum all together, its a breeding ground for unicorn milkers, rainbow chasers and candy cotton farters.
    Reputation: joe_bloe's Avatar
    The valve parts of a Presta valve are hanging out in the open. Don't you think the only thing holding air in your tire should be protected?
    The only time I use a cap is on my spare w/ presta valves to keep the metal part from rubbing through the tube. Otherwise I don't bother.
    We get titles?
    Reputation: upNdown's Avatar
    I'm not saying that's not what happened, but I'd have a much easier time believing that you bent them using a hand pump, than believing they were bent by flying debris.
    Quote Originally Posted by trogdor
    I think everyone who wears a helmit should carry around an old crank arm, then when you see someone without a helmit on, give them a good wack in the head. That'll teach them to flaut their helmit-less noggins out in public.
    www.bigrobracing.co.uk
    Reputation: robdeanhove's Avatar
    Dec 2005
    Keeps crud out of the valve in the little holes that expose the seal
    excellent point by crashedandburned about protecting your spare tube!
    Quote Originally Posted by upNdown View Post
    Nope, I'm very careful with the pump and noticed it while cleaning bike after hard ride. Where I ride there are lots of loose river rock and sticks, as I'm flying along I often hear and feel them bouncing around and pinging through my spokes....un-nverving first time and now just ignore it. I have scrapes on rims and spokes from this and have broken spokes and nipples from it once.
    Nickel Havr
    Reputation: Eckstream1's Avatar
    They look kewl...
    Quote Originally Posted by William Blake
    Great things are done when men and mountains meet. This is not done by jostling in the street .
    DynoDon
    Reputation: manabiker's Avatar
    Looks like a Rocket coming from a Rocket Ron...................sounds/looks like a good reason to me... and all the above reasons too..!!!
    <a href="http://photobucket.com" target="_blank"><img src="http://i892.photobucket.com/albums/ac122/manabiker/P8280001.jpg" border="0" alt="Photobucket"></a>
    Four wheels transport the body,
    Two wheels transport the soul !!!!
    Caps keep dirt out, keep the sticks or rocks from bending the valve...all the reasons above. Running without them just adds one more thing that can break when you ride.
    Reputation: Shalom's Avatar
    Nov 2008
    Great alignment of the star with the valve hole!
    I don't bother on prestas. Never had an issue with the bending of the valve, other than the muppet (me) pumping the tyre up.
    Schraeders, it keeps the crap out so that the valve actually works.
    T.W.O
    Reputation: pfox90's Avatar
    Aug 2010
    the only reason they are on prestas is for shipping purposes... i dont see any point on keeping them on after the fact
    ------__o
    ----_`\<,_
    ---(_)/ (_)
    Reputation: Glynis27's Avatar
    Had a stick reach out and rip the tip off the valve of my rear tire once. Instant flat and no spare tube. My patch kit was of no use, of course. Not very likely that it will happen again but I'm using the caps.
    '15 Soma Wolverine '12 Soma Analog SS '10 Transition TransAM '07 Felt F1X '97 Schwinn Mesa SS '89 Fuji Saratoga '86 Fuji Club
    Hi.
    Reputation: jtmartino's Avatar
    I don't use them, and haven't used them in 15 years. I've never had a single problem that wasn't caused by me while inflating.
    But really don't see a problem, unless you're a hardcore weightweenie .
    good to know there is a reason to have them
  1. Looking for SID100 Valve Caps
    By burcak in forum Shocks and Suspension
    Last Post: 05-04-2010, 04:33 AM
  2. Jesus Valve Caps
    By amblake50 in forum Singlespeed
    Last Post: 12-21-2009, 11:21 PM
  3. Jesus Valve Caps
    By amblake50 in forum 29er Bikes
    Last Post: 12-21-2009, 01:55 PM
  4. Look at my cool valve caps
    By Breitling in forum Gary Fisher
    Last Post: 08-12-2007, 07:01 PM
  5. Presta Valve Caps - to use or not to use?
    By psunuc in forum General Discussion
    Last Post: 11-02-2006, 03:11 PM
