Results 1 to 14 of 14
    Jul 2013
    Another "is this bike worth it?" Thread!
    Hiya guys,
    so I have the opportunity to get what seems to be a 2000-2001 specialized enduro fsr pro for about $100. It needs brake work and most likely a tune-up from an lbs. it has a fox coil over in the rear and manitou forks. I think it is a large frame. Brakes are the rim style, not disk. And that's about all I know. The person selling it doesn't really know about bikes and wants it gone. Any help and advise is appreciated. Just trying to get into this sport and have fun on a budget, so go easy
    Jun 2013
    Well, if it's an FSR Pro it should have XT/XTR level components on it which means the parts alone are worth way more than $100. The main potential downside to purchasing any full suspension bike is you may have to spend a chunk of change having the shocks overhauled to get it in mint condition again. You say you "think it is a large frame". Well, don't buy it unless you actually fit on a large frame. That would make it a terrible decision.
    Moderator Moderator
    Quote Originally Posted by The FNG57 View Post
    Hiya guys,
    Very, very common for the chainstays to crack on older FSRs - look closely at them where they are joined near the bottom bracket for hairline cracks. They used to hand out replacements like candy under warrantee, but I'm betting you'll have a tougher time finding one now.
    Jul 2013
    I'm 5'11" 180lbs. I think that puts me on the edge of med/lg frame. Would it be hard to find a chainstay at all, or just a stock one?
    I Tried Them ALL... SuperModerator
    Reputation: Cayenne_Pepa's Avatar
    If it doesn't fit right - even a FREE bike is not worth it. That said - buy it if the bike fits and needs a basic tune-up, which will most likely cost you close to $150. Get it done right; have them replace all the old brake pads...even if they show minimal wear. You just never know how long those have been hanging up in a garage, and dry-rotting rubber can prove catastrophic, out on the trail.
    "This is a male-dominated forum... there will be lots of Testosterone sword-shaming here" ~ Kenfucius
    Re: Another "is this bike worth it?" Thread!
    Are you sure that bike isn't stolen? At that price, it seems kind of too good to be true. :/
    Sent from my GT-I9300 using Tapatalk 2
    Jul 2013
    It was donated to a non-profit. That's who's selling it. I'm pretty sure it's not stolen.
    Fat-tired Roadie
    Nov 2007
    $150 is not too good to be true on something that age.
    FS makes things a bit more complicated. Technology has come along in the last twelve years. And sourcing suspension parts can be difficult when everything's a bit older.
    If it was a hardtail, I'd say "goes, stops and shifts" is worth $100. Since it's FS and it sounds like it needs work... I think I'd pass unless I had a good idea of how much work, exactly.
    Demon Cleaner
    Reputation: Structure's Avatar
    Those frames used bushings and not bearings. Be sure to check out all the pivots for squeaking and play. You can probably rebuild it still, but it's one more thing to add to the list. If you are handy, you should be able to do it yourself.
    I think the price is about right.
    Bicycling is politics by other means.
    Jul 2013
    I hate it when people give me good advise that I don't want to hear! Anyway, if it makes any difference, it has shimano xtr brakes and stuff on it. I'll just put up the link. I hope no one sees this and tries to out-bid me on it though...that would suck.
    Specialized FSR Enduro Pro Lightweight Enhanced Aluminum Mountain Bike | eBay
    No worries. Even though I have the money for it - bringing it back up "to snuff" is simply not worth the added cost. Good luck, bidding!
    I didn't do it
    Reputation: Mookie's Avatar
    It looks like its local pick up only so presumably you're in the Seattle area and it won't be an issue.
    Reputation: alphajaguars's Avatar
    I'd do it, but then again I am a moron.
    Jul 2013
    I'm close-ish to Seattle. And...
    Quote Originally Posted by alphajaguars View Post
    ...that's the answer I like more
  1. Another "what's it worth" thread
    By csbrown28 in forum General Discussion
    Last Post: 04-29-2013, 10:14 AM
  2. Replies: 2848
    Last Post: 01-01-2013, 09:36 AM
  3. "which bike" thread-Trek Mamba or Cannondale SL3
    By Striker01 in forum Beginner's Corner
    Last Post: 08-02-2012, 06:46 AM
  4. Replies: 2
    Last Post: 10-13-2011, 07:34 AM
  5. Replies: 20
    Last Post: 03-25-2011, 05:00 PM
