    Jun 2013
    Caution;  Merge;  Workers Ahead! Always replace damged/bent rear hangers
    You should always replace your rear hanger if it becomes bent or damaged, especially if you are into racing. I have been hearing a few peple lately saying that you can just straighten out damaged hangers, but personally i would advise against that. Due to its structure Aluminum doesn't stand reshaping very well, and will be easier to break if straightened. Breaking a rear hanger in the middle of a ride is not a nice feeling. Last week mine broke in the middle of a race(it got sheared of by a piece of deadfall), bending some of my spokes and destroying the cables to my rear derailleur. In its self it was a pretty small thing and will be easy to fix but it cost me the race as the rules state that you must ride your bike over the finish, which for me was 9km away, and more importantly I lost my second place season finish with my mountain biking club, dropping back to third. There was nothing I could do in this situation, but always make sure your bike is in top shape so unfortunate accidents don't happen to you.
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by DarkenedflameX View Post
    Yet brand new hangers need to be aligned. They are rarely straight.
    A slightly bent hanger can be straightened (some better than others) and be fine. To ALWAYS replace a tweaked hanger is a waste.
    mtbtires.com
    Oct 2012
    I would think this depends a lot on the frame... some frames have replaceable hangers, some don't. Some are made out of carbon fibre and don't bend well. Others are made out of steel which bends safely and easily.
    turtles make me hot
    Reputation: NYrr496's Avatar
    I have never bent a hanger...
    It's always a catastrophic failure that forces me to replace the hanger trailside.
    I like turtles
    TXTony
    Guest
    Quote Originally Posted by shiggy View Post
    This
    Happy Trails
    Reputation: Scott In MD's Avatar
    Have you ever used a bent and straightened rear derailleur? Did it explode? Reason I ask is because I have one on my bike for three years that shifts perfectly. I asked LBS wrench if I should get a new one and in classic LBS wrench language he said, "Sure, if you don't trust my work and want to waste money."
    Just asking .....
    Nickel Havr
    Reputation: Eckstream1's Avatar
    Quote Originally Posted by NYrr496 View Post
    This...
    I carry a spare hanger with me in my CamelBak.
    Quote Originally Posted by William Blake
    Great things are done when men and mountains meet. This is not done by jostling in the street .
    Dec 1998
    Quote Originally Posted by evandy View Post
    I have never seen a carbon frame without a replaceable hanger.
    Steel and ti frames do not need them. The metal can be bent (rarely happens), straightened and aligned many times with no issues, and replaced by a frame builder if necessary.
    mtbtires.com
    My little friends
    Reputation: EABiker's Avatar
    I've bent them, then straightened them out, (on the trail), and had them work fine; other times they caused drivetrain issues. I usually get a new one and install it, then straighten the old one and keep it for a trail spare, until I get around to getting a new spare. I've never had a straightened one break without my causing it to!
  1. Bent Crank, what to replace
    By NJTransplant in forum All Mountain
    Last Post: 03-05-2013, 01:15 PM
  2. Replace slightly bent disk rotor?
    By bluronthetrails in forum Brake Time
    Last Post: 03-28-2012, 06:41 AM
  3. Bent chain ring: try to repair or replace?
    By Spykr in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-25-2011, 07:52 PM
  4. Replies: 5
    Last Post: 09-04-2011, 07:40 AM
  5. Rear derailleur hangers
    By the-one1 in forum BMC
    Last Post: 03-04-2011, 11:57 PM
