Much too small - manufacturers guidelines are considered accurate, but if you've been riding that bike for any length of time - get to a shop for a re-size right away.
I'm 6ft, ride a L/XL frame.
I like Sand - I don't like Witches
That looks really small to me. I am 5"9" and ride a medium to large frame depending on model
Yeah, looks small to me also.
I'm 5-11 and ride medium, but could easily fit a large.
You're not going to see all that much of a weight difference by going with a larger frame. I would see if you can go to the LBS and try out your same bike in a couple different sizes and see what you think.
Sinister Bikes
Wraith Bicycles
Sunday River Mtn Bike Park
NEMBA
Wachusett Brewing Co.
Thanks for your advice everyone. I guess first step is to go to my LBS and try out the same bike one size up and see what happens.
Couple other things to try -
- a longer stem. A little bit can go a long way.
- angle your brake and shift levers down more. See how your arms break at the wrist in your picture?
Hi Bigb, what who said? Eddy Merkcx, AndwSwitch or any of the previous respondents?
 Originally Posted by Torsten
what who said?
The '^' is pointing to the previous post.
Looking at the bike that you currently have which looks very small, it might be worth trying a bike with a frame that's a couple of sizes bigger.
The bike feels a tad small to me, but then again I like the fact that it is light ad I can really throw I around a lot.
The weight difference between different frame sizes wouldn't be very much and you probably wouldn't notice the difference.
What size frame is that bike ?
How tall are you ?
Did a bike shop measure you up for that bike ?
Shaman
Bike does look a bit small. Shorter stems mean better control in cornering and over-all handling so a longer stem should only be a temporary fix. Angling your brake levers down is great, but you'll be able to tell where they need to be when you're in your attack position. Arms bent, elbows out, chest lowered. That will help with the pressure on your wrists and hands.
Skills coaching loved by passionate riders of all levels and trusted by the pros.
www.betterride.net
Thanks for the great advice everyone. The bike is a Trek Fuel EX 7, virtual size 19.5" (actual 18.5"), 5 inch travel. I am 190cm, which I believe equates to roughly 6ft2. I live in Manila so bike choice is limited. I have looked around and two bike frames which are available at 21.5" are the Giant Anthem X (4 inch travel) and the Giant Reign X (6 inch travel - both frames 2012). Does any of you have experience with any of these and what would the difference be switching from the Trek Fuel other than the reduced travel and slacker head of the Anthem?
If it's just to sprint-out rides, go with the 4" travel Anthem, but if there's an option to explore varied terrain, build the 6" bike. The Reign will feel a little slower responding, the trick is to stay ontop your pedal rpm, the bike stays lively that way. Have not ridden either, Giant has a good image and a good review always attached.
Did you take the Trek with you from elsewhere? Otherwise, your local Trek dealer should be able to get you another Fuel, if you'd prefer. I demoed one recently, and liked it. I remember being somewhat underwhelmed by the Anthem (or Trance? Whichever one I rode...)
Nothing wrong with checking out some other bikes if you're curious. I would just be surprised if you have to change.
Whether you switch bikes or not, dialing in the fit, at least in terms of working for your body, should give you some insight into the bike size you need. My favorite measurement lately is reach, although effective top tube is also popular. If the stem that makes the bike fit you right causes it to nosedive, going to a bigger frame should help.
At the end of the day, the goal is to get you on a bike that you can set up so it doesn't hurt you and you have good range of motion, and that has the right weight distribution.
To say what has already been said... The bike you have in the picture looks quite small. It is too short, and has too short a top tube (distance between seat and bars). You could go up one size, or maybe even two depending on the feel you like.
I am 6'3" (190.5cm). I ride a Large Giant Trance full suspension (2009 26" @ 20.5" frame) and a XLarge Cannondale F29 hardtail (2013 29" @ 20.7" frame). My FS is just a bit on the small side, but I like it for agility. Whenever I see my reflection in a street window I always think "who's the fat guy on the little bike?"
When I got used to my XL hardtail, I found I could maneuver it just as well.
This weekend I am entering a local all mountain (blue level) 25K competition. Mi am going to push my seat back a little and put on a stem that is 10mm longer and see how it goes. If that still causes the same issues I will go one size up, either another Fuel or the Giant Reign I guess. I am a little sad as I have come to like the amazing agility of this (small) bike. I also own a 21" hard tail (Trek Mamba) and hardly ride it anymore other then 3 hours + fire trail rides which we hardly do here in the Philippines. I shall keep you posted and in the meantime thank you all for your generous advice!
Wait until next week to change stuff.
Never screw with your bike right before a race.
Sound advice, which I will take!
Did some more researching. Sadly not much good news. Trek does not sell "frame-only" for the Fuel so that idea is out of the window. As regards the Giant Reign, my next choice, they recommend a 160mm shock when I currently only have 120mm so I would have to invest in a new fork. Then the seatposts are different (30.9 for the Giant vs 31.6 for the Trek), so I would loose my KS Lev as well. Further adjustments to the rear axle and front derailleur would make changing to a Giant Reign a senseless and unaffordable exercise but sadly there is not much more choice here in The Philippines ( other than Specalized which is ridiculously expensive). Any great ideas out there, I could really use some...
I am sure there are many other Frame only options that would allow you to utilize your current components. I just googled "bike frame order" and several options came up.
Advice needed!
Can also try moving the saddle back along with the longer stem but that bike looks so small on you I don't think adjusting all that is going to make a huge different, not so much it stops playing on your mind the whole time you ride it.
What is the 2nd hand market like in the Philippines? I'd try and source a used Fuel frame, swap the parts and sell your med frame.
Or just buy a new complete bike and sell your current one. As you've noticed, cross-compatibility isn't as easy as it used to be.
I have a GREAT deal on a Giant Reign. I have read it is spec'ed for a 150mm fork. I cannot afford a new fork at the moment but I have a fox with 120mm from the Trek I could use for the time being. Could I ride the Reign temporarily with this until I have saved up enough for a new 150mm travel fork? What would be the consequence? Thank you in advance for your advice!
Relative to how it was designed to behave, the bike's going to have a steeper head angle, enough to notice, and a lower front end, possibly enough to give you trouble with your handlebar position.
There are going to be other changes, but I'd expect them to be pretty minor.
It's pretty slack, so I don't think steepening it would be so bad, in general.
If you already use a setback seat post and slam your saddle all the way back, you may have trouble with your saddle position.
By big dave in forum General Discussion
Last Post: 11-17-2013, 02:26 PM
By highdelll in forum Off Camber (off topic)
Last Post: 02-05-2013, 11:40 PM
By cigarlover in forum Endurance XC Racing
Last Post: 11-10-2012, 03:41 PM
By Swords in forum Lights DIY - Do It Yourself
Last Post: 06-01-2011, 11:43 PM
By bjv1176 in forum Beginner's Corner
Last Post: 05-28-2011, 11:02 PM
- You may not post replies
- You may not edit your posts
Forum Rules
