    adjusting headset and fork
    Been riding for about a month and my fork is wobbling back and forward from the headset. Do I just need to tighten or should I take everything apart and reinstall?
    There's no app for this.
    Reputation: JimC.'s Avatar
    Stop riding immediately
    loose headset will ovalize your head-tube, and then your frame is useless and non-repairable.
    This has been discussed many times; here's an URL to read up on, failing that, take your bike to the shop and don't ride it there.
    Good luck, Jim
    go to this part: Headset Adjustment - Threadless Type
    Park Tool Repair site
    if you want to do it your self loosen the bolts on the side of the stem first than tighten the top bolt make sure you keep the handle bars straight than tighten the stem again, if it is not tight than it maybe the forks stem tube was cut to long or the bike could be damaged, did you put new forks on it?
    INope its the original fork. Thanks for the link. I will definately read up on it.
