Results 1 to 29 of 29
    About to buy my first real bike and had a few questions
    Hey all,
    After 3 months of riding my mongoose dual suspension walmart with my freinds im going to jump in and get a true mountain bike Ive decided on a specialized hardrock based on feel (if anyone has any other suggestions feel free to let me know) and had a few questions:
    1. Should i start with clipless pedals or just get a feel for everything first?
    2. If i want to upgrade the fork and the brakes could i transplant those parts to a better frame later on down the road?
    3. Would a full face be overkill for XC? (Thinking about the 661 Comp II)
    T.W.O.
    Reputation: mimi1885's Avatar
    Pedals is up to you it does not take much to get used to.
    If you are going to buy a new bike and immediately upgrade, then might as well spend a bit more for a better model with already good components, it's cheaper that way.
    Full face helmet is not overkill for XC but you may get overheat on the climb.
    Have fun.
    i was just wondering if say i bought a fox front later on down the road for my hardrock could i just transfer the fork to a newer frame?
    Quote Originally Posted by Kinetic07 View Post
    That really depends, the steer tube may be different diameter. Or when you tube the tube, it could end up too short for the new frame.
    OG Ripley v2
    Carver 420 TI
    Reputation: square's Avatar
    Jun 2010
    chances are when you want to upgrade to a fox fork (or similar) you will just start looking at better bikes. that's how it worked for me anyway.
    T.W.O.
    I agree with square. What's your budget?
    I really have up to $1000 to spend but i would like to keep it around 600-800 range
    Reputation: jpeters's Avatar
    I was probably going to try and support one of the LBSs in my area but that does give me a good idea of what to look for, Thanks! Does anyone else have any suggestions?
    T.W.O.
    I'd say shop around different lbs near you do your homework on price before you buy and don't plan on big ticket upgrades like fork or wheel til your next bike. Or look at bd for better components spec since you are getting a hardtail it makes very little difference.
    If you dont mind me asking what is bd? and would a marginal upgrade to lets say a rock shox dart 2 100mm be worth it or jsut save my money? because as far as i have read the fork is the weakest point on a lot of these entry level hardtails... This is really helping me out btw
    Reputation: theMeat's Avatar
    Agree with Mimi 100%. If money's an issue it's so much cheaper to get a better bike first, even if you have to wait a little. Haste makes waste.
    Suggestions are good but how you like how the bike feels is the most important. Test ride as many as you can. Your friends, lbs, rent, whatever. Check out bikesdirect website also for some killer deals.
    Don't know how you feel about buying used but I do all the time and you can get alot more bike for the money. Have money left over for gps, backpack, a trip, ect.
    Whatever you decide, shop around, buy as much bike as you can afford, don't look back, and enjoy the hell out of it!
    Round and round we go
    T.W.O.
    We don't speak this name on the forum j/k. It's bike direct.
    If you want the best bike for the money and willing to do some homework then get used. Best bang for your bucks just have to hit the book/website and research. Use this link to narrow down the search. Hey for a grand you can probably get some full suspension as well. http://bike.jaxed.com/cgi-bin/bike.c...=d&submit=+GO+
    @themeat, thanks for the prop.
    turtles make me hot
    Reputation: NYrr496's Avatar
    Save up a little more money up front and get a Rockhopper or something. Hardrocks weigh a ton and you'll spend more money upgrading the Hardrock and not have as good a bike.
    I like turtles
    Reputation: ldollard's Avatar
    Yeah the rockhopper actually costs aroun $800 or $650 used for a 2011
    What would be the difference between the rockhopper and the hardrock other than price and weight? Because the components on the rockhopper and the hardrock disc are the same
    Sent from my HTC Sensation 4G using Tapatalk
    Reputation: sgtcurry's Avatar
    Mar 2011
    Quote Originally Posted by theMeat View Post
    Agree with haste makes waste. I bought a decent starter bike and immediately upgraded the fork and the brakes, then after two months and spending 800 on the bike and upgrades I end up spending $1300 for a new one. Should have just spent that much in the first place to save me a lot of gas, time and headaches.
    I would either buy the cheapest bike that you can enjoyably ride and ride it into the ground without putting money in to it while putting money away for your next bike OR buy the best bike you can afford.
    On the upper end of your budget you can get a "decent" set of components, brakes and fork; you can get out of X4/Alivio, Suntour XCM, tektro novela land.
    What I personally would not do is buy a bike and hang really nice components on it.
    $1,000 is the bottom end of finding a good bike. I too suggest in looking into a used ride. Craigslist can be a great place to score a good bike and I see $2k+ bikes go for under $800.
    I recently picked up a 2010 Norco Fluid3 at my LBS for about $800 off. For me it was a toss up between the Norco and Giant Yukon FX but went with the Norco since I got more for my money.
    I agree given your price range a good used bike may be the way to go. I had a similar budget to you that kept going up because I wanted a better bike and components, eventually I bought a Cannondale F29 Caffeine for about a 1/3 of what it was new, it had only a few hundred miles on it. It also had about $500 worth of upgrades the previous owner added. So I guess if I were you I would find a used bike in good condition.
    http://bham.craigslist.org/bik/2515907750.html
    What do you guys think about the price point on this gary fisher marlin disc versus a brand new specialized hardrock?
    Jun 2010
    they are asking way too much for that marlin...plus it's a 21"...how tall are you. nice bike though.
    im 5'7" almost 5'8" but the main problem with buying used in my area is that not too many people sell used mountain bike equipment. Ive been looking around for the last 2 weeks and havent found much
    Well, it's your money and time but maybe a drive to an area with more used would be wise.
    Jun 2010
    21" is way too big. you should be looking at 15-17" bikes.
    my area seems to suck for (good) used bikes on craigslist, but there's always ebay. problem is you can't ride first, so you need to know what you're buying...
    21" is too big indeed. I don't know that used will necessarily get you a much better bike for your money. It very well could, I was hitting myself after missing a couple local used bikes. It takes patience and a little bit of luck.
    A good second option is past year/demo models. Actually ask your shop if they have any. Be wary of the sizing, and don't get pushed on to something wrong for you. Also, go to many shops.
    Just to give you an example, I went to 5 shops and called 3 more in shopping for my bike. I waited and ended up finding a past year Trek 6000 for about $600. I also got offered a Giant Yukon FX for $700. You seem like you want more for your money, so put in some leg work.
    Reputation: RabEd Ewok's Avatar
    Quote Originally Posted by square View Post
    As I do agree 21" is way to big for your size Kinetic07, I think that 15" is a little small for your size. Yes I am new to all of this, but I am your height as well. I have a 17.5" and it fits great. I know not all people are the same and that different bikes fit differently as well. But I have been on a 18" Raleigh as well and liked how that was too. So my suggestion is 17" to 18", no higher, and probably not too much smaller either. Just my opinion.
    2010 Gary Fisher Marlin
    Upgrade-Wellgo MG-1 Pedals
    If you don't come back banged up and bruised, you didn't go hard enough!
    Reputation: Meesta Chow's Avatar
    This is an awesome web site. Much thanks mimi1885!!
    I'm in the same boat. Thanks for the helpful advice here.
  1. Replies: 12
    Last Post: 04-20-2011, 08:10 PM
  2. Replies: 3
    Last Post: 10-27-2009, 06:21 AM
  3. First REAL mountain bike, couple questions
    By DirtRider86 in forum Beginner's Corner
    Last Post: 10-05-2009, 01:18 PM
  4. First real ride on first real bike
    By Bubbles & Me in forum Beginner's Corner
    Last Post: 04-18-2007, 07:56 PM
  5. Real tire circumference Mtn bike vs Rd bike
    By Chester in forum General Discussion
    Last Post: 10-25-2004, 06:07 PM
