Results 1 to 8 of 8
    Jul 2014
    9yr old cant move front derailer grip shift, replace with trigger shifts or derailer
    so as the title says my 9yr old girl cant move the left grip shift on a shimano revoshift its to hard to move the derailer. i think it has high spring tension on the derailer
    my first thought was to replace with a trigger shift, but maybe possibly the front derailer needs to be changed to something better.
    i have gone thru and removed the front derailer shift cable to make sure its not kinked, it has a smooth opertation.
    my third thought is thats its a new bike and maybe through use it will lighten up.
    so any help would be great
    i am new to this forum and look forward to learning alot
    my next bike will be for me but im 6'5 so cant wait to look thru the tall guy section of the forum
    thanks
    Jun 2005
    I would pity any kid trying to learn on grip shifts. First thing I would do would replace it with a trigger shift whether it worked or not.
    Fat Is Where It's At Moderator
    Reputation: DiRt DeViL's Avatar
    Triggers might be better, depends on his hand strength. When my kid was that age he used the palm of his hand to move the lever but eventually was able to deal with the levers just fine.
    Jul 2014
    so a front derailers spring tension wont change from different makes they are all gonna take some force to move? the left 3 speed trigger will be indexed?
    I'd do triggers just for ease..The derailleur controls the stiffness of movement, but triggers offer leverage that grip shifters don't.
    Sent from my 831C using Tapatalk
    Triggers can be difficult too.
    I've found cable and housing does make a difference.
    This Jagwire/Novara run as a continuous will be lighter shifting for front and rear.
    Lined housing and slick coated stainless cable. Superglue before you cut the cable.
    Novara Shift Cable Kit at REI.com $19.
    Simpiler thing to do might be get rid of the front deraileur kills me how kids bikes come with huge front chainrings, keep the smallest ring if she doesnt need the big ring(s).
    XC, Road, XXC, Endurance, Mtn, All-Mtn, Cross, Gravel, just go have fun on 2 wheels!
    Jan 2014
    i was thinking that perhaps you could suspend the rear wheel of the bike in the air slighly and then let her get on the bike and pedal (the bike would be stationary) and then work with her on getting down the feeling of shifting.
    my duaghter is the same age and her bike has grip shifters and she is able to shift.
  1. XX1 Grip shift - Accidental Shifts
    By GTR2ebike in forum SRAM
    Last Post: 01-19-2014, 08:42 AM
  2. Front derailer only - will a TRIPLE shift a DOUBLE?
    By ncj01 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-11-2013, 06:11 PM
  3. SRAM XX Trigger Shifters vs. Grip shifts
    By blaadd in forum Weight Weenies
    Last Post: 10-16-2012, 04:39 AM
  4. crashed, now front derailer wont shift
    By apheod in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-03-2012, 10:45 AM
  5. Front derailer won't shift to small ring while riding
    By hotrozz in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-14-2011, 08:36 AM
