    Mar 2014
    90mm front hubs?
    Hello,
    I'm looking to build a front wheel for a bike that has 90mm dropout spacing in the front fork (it's an older Schwinn). The existing hub has seen better days and besides, I thought it'd be fun to work with something a little more modern (I don't care for the old front hubs that don't have locknuts).
    However, after a bit of searching, it's not looking like anyone is making front hubs in this size. I see Sturmey Archer has a drum brake hub and someone on ebay has some old Wald hubs ... anyone know of any other options for 90mm front hubs?
    Fat-tired Roadie
    Nov 2007
    Tough one. I don't know if that was ever standard. Schwinn manufactured enough volume to do whatever they felt like. They had some weird rim/tire sizes too.
    Couple approaches.
    You could cold set the fork to take 100 mm. Sheldon Brown had good articles on that sort of thing.
    You could look for a hub with really thick jam nuts and substitute something thinner.
    You could look for a sealed bearing front hub with dust caps and omit them.
    Anything involving leaving out a part may run n you into trouble with the length of the axle.
    Also browse the vintage/retro/classic forum and see what other people have done.
    Mar 2014
    Thanks for the reply!
    Sorry, I hadn't noticed there was a vintage bike forum!
    And thank you for the suggestions ... I'm a bit hesitant to cold-set the fork, but that would certainly multiply my options by a ton.
    If you don't want to try ,a shop might do it for you.
  1. So who else makes dem front-spaced 135 hubs?
    By canyonrat in forum Fat bikes
    Last Post: 12-31-2014, 02:48 AM
  2. Replies: 29
    Last Post: 12-14-2014, 02:09 PM
  3. How much do Maverick front hubs go for...?
    By patineto in forum Maverick
    Last Post: 01-18-2013, 09:43 AM
  4. American Classic Front Hubs
    By in the trees in forum Wheels and Tires
    Last Post: 10-26-2012, 02:19 PM
  5. who makes stan's front hubs?
    By head in forum Wheels and Tires
    Last Post: 10-11-2011, 11:48 AM
