Results 1 to 5 of 5
    9 speed cranks on 8 speed bike?
    Say I wanted to upgrade my stripped square taper BB and cranks to an isis or raceface BB and crank, could I do this on my 8 speed bike, since the more sturdy BB/crank combos are designed for 9 speed? or does it not matter at all? Thanks
    2018 Santa Cruz Tallboy
    Southern Maine
    Reputation: JSumner13's Avatar
    It doesn't matter. It will be compatable.
    what about rear derailleurs? Does bike speed matter?
    Southern Maine
    As long as you set your high and low limit screws correctly a 9 speed derailleur will work fine with your 8 speed cassette.
    pronounced may-duh
    Reputation: Maida7's Avatar
    Apr 2005
    The 9spd systems use a thiner chain and I think the chainrings are thiner. So you can use an 8spd chain on 9spd cranks and derailers. I have done just what your attempting with good results. I would not try an 8spd chain on a 9spd cassette. Thats where things get very particular. Your cassette, chain and shifters should all be the same spd.
