Results 1 to 6 of 6
    Aug 2005
    8speed/9speed crankset question
    I need to replace my crankset as two of the three chain rings are worn and its an old system.
    I have a few questions however.
    My bike currently has an 8 speed drivetrain, will a "9 speed" crankset work with the 8 speed system. I don't see why not as most of the movement is on the casset side and not up front, but I'm not sure.
    Also, it is possible to replace "types" of BB's correct as long as they are the same size? My bike is old and currently has square taper, but most of the new systems use other BBs so I figured I'd replace it at the same time if possible.
    Thanks in advance for any information.
    ~ Eric
    Reputation: InvictaS1's Avatar
    Mar 2005
    there is no such thing as a 8 or 9 speed specific crankset. you can use any three ring crankset. you should also plan on buying a new bottom bracket as well unless you get a new crankset that uses square taper bb's.
    ride hard take risks
    Reputation: dogonfr's Avatar
    Jan 2005
    I'll 2nd that!!
    lurker no more
    Reputation: oreo's Avatar
    If he's going to a 9 speed set up then what about shifters, does method need a new set? I know SRAM made 2005 x.7 triggers that were 8/9 speed and the x.9 triggers were 9 speed only. Would he need a new, longer chain too?
    Quote Originally Posted by method
    ~ Eric
    Jan 2005
    Very true Dr oreo, he will need a new 9 speed chain anyway.
    I Love my Rize
    Reputation: danoalb's Avatar
    Dec 2005
    Read The Quote
    Quote Originally Posted by oreo
    He said he is staying with a 8 speed system, just changing the cranks.
