I'm thinking about doing a 2x10 setup sometime in the near future. Would this require buying a entirely new crank and cassette, or can I just take a third ring off my crank set and add more gears to my cassette?
*forgot to add that I have a 2010 Gary Fisher Advance.
James, you'll need the following: 10 speed shifters, 10 speed cassette, 10 speed chain, 10 speed rear derailleur. I would just stick to 9 speed until you buy a brand new bike equipped with 10-speed.
You cannot add another gear to your evenly spaced 9 speed cassette.
If you get a 10 speed cassette you may need a 1mm spacer to between the cassette and hub. It all depends on what hub you are using. I know the Mavic hubs require the spacer when going from a 9 to 10 speed cassette.
Thanks for the info guys! Didn't think it'll turn out to be that complicated. I guess I'll have to do more reading on my part. I like the way my bike is currently set up even though it is stock, but I almost never use the biggest ring on my crank set. I might as well keep riding till eventually the components wear out, then do a major components upgrade.
Why not just go 2x9 then? You'll have to decide whether you want to lose a little off the top or bottom but that should go a long way. Just change the chainrings and maybe the front D and I think you should be good.
Before SRAM claimed to invent 2x10 (like Al Gore inventing the internet...) people just took the large chain ring off their cranks. Get a bash guard to replace it. Be happy.
If you've thought about it at all you should. Adding a bash guard is safer for your legs and way more convenient on log-overs. My new bike had a 2x10 or 3x10 option on the build kit. I specifically went 3x10 to replace the big ring with a (real)bash guard. The available 2x10 specific bash guards are a joke IMO.
Thanks Paulrb02, now i'm really thinking about just doing a 2x9 and taking out the larger ring for a bash guard. It's probably the most cost effective way to lose a little bit of weight and get rid of the large outter ring that i don't use. It just makes sense and i don't have to spend a lot. I appreciate all the info guys, the biking community in this forum is great, compared to car forums i've been in the past, you guys rock!.
Related Threads
Mountain Bike Reviews Forum
15.4M posts
515.2K members
Since 1990
