Results 1 to 9 of 9
Thread: 29er question
    29er question
    If I buy a 29er do I need a smaller size than I do in a 26er? I am assuming the 29ers sit taller.
    Riding or Drumming
    Reputation: funkydrum's Avatar
    Probably not a smaller size.
    Head to your LBS and try them on for size. How it feels is paramount...
    Tallboy
    Salsa El Mariachi SS
    Salsa Vaya
    Salsa Mukluk
    Surly Big Dummy
    Quote Originally Posted by funkydrum
    So if I need a small size 26er I will also need a small size 29er?
    AZ
    AZ is offline
    Reputation: AZ's Avatar
    Most likely , but you need to try them out .
    Reputation: Nubster's Avatar
    The sizes are relative. Just because the 29er has bigger wheels it is not necessarily a "bigger" bike so the sizes will be comparable. My 26" bike is a L and my 29er is a 21" frame which would be a L or XL.
    Reputation: fatboypup's Avatar
    x2 the frame is the frame ...... youll still need the same
    '10 Rockhopper SL Comp 29er
    Fat-tired Roadie
    Nov 2007
    29er sizes tend to run a little different in a lot of brands. If you have a bike you like, measure or look up the effective top tube length. That should give you an approximate size for 29ers to try. Don't be afraid to try bigger and smaller too, though.
    Terrain Sculptor
    Reputation: Trail Ninja's Avatar
    Quote Originally Posted by AndrwSwitch
    29er sizes tend to run a little different in a lot of brands. ... Don't be afraid to try bigger and smaller too, though.
    +1
    For me a 20.5" Marin HT was too small and a 18" GF fit just right. You gotta ride them.
    247 is offline
    I would ride the same size with Gary Fisher's(26 or 29).
