Results 1 to 6 of 6
    May 2013
    26 tire question.
    Hello, i have trek 4300 26". Currently the tires i have on there is 26x1.95, am i able to put on wider tires such as maxxis 26x2.35? Thanks
    Sent from my LG-MS870 using Tapatalk 2
    Jan 2013
    26 tire question.
    Quote Originally Posted by Spetsnaz View Post
    i'm new to this...
    look on your wheel.
    the recommended sizes might be there.
    joel
    2013 Trek Fuel EX 7
    IMBA Member
    May 2013
    Re: 26 tire question.
    The actual wheel size is 1.5 and I've had 26x1.5 street tires on them. The wheel does not say recommend size of tire :-(
    Reputation: Danielrg_usa's Avatar
    Really, it depends on whether the tire fits in the frame or not. My opinion at least. a wider rim will give the tire more stability on the rim but you should be fine running a 2.35" tire on a 1.5" rim.
    May 2013
    Ok, thank you very much.
    Bicyclochondriac.
    Quote Originally Posted by Danielrg_usa View Post
    This^^^
  1. Front tire and rear tire size comparison question help?
    By Yellowr6 in forum General Discussion
    Last Post: 02-21-2012, 05:50 PM
  2. Front tire and rear tire size comparison question help?
    By Yellowr6 in forum Wheels and Tires
    Last Post: 01-26-2012, 12:54 AM
  3. Tire Question
    By Tidezealot in forum General Discussion
    Last Post: 07-18-2011, 11:17 PM
  4. Tire question....
    By Terry66 in forum Surly
    Last Post: 04-14-2011, 12:03 PM
  5. Tire question.
    By sasquatch rides a SS in forum 29er Bikes
    Last Post: 02-24-2011, 01:14 PM
