Results 1 to 7 of 7
    Sep 2013
    262.1 to 262.35 tire
    Can someone pls tell me if a 262.1 tire and a 262.35 tire have a big difference of wide or is it only 6mm difference according to my ruler? My current tire on my mtb is a 262.1 and I have about 10mm of clearance left between the width of my tire and my frame at the back. Can I fit a 262.35 tire on it wif 10mm clearance left?
    Reputation: George Gr's Avatar
    2.1 and 2.35 numbers are not that accurate.
    What you have to look is on the manufacturer's web page the number in parenthesis after that number. It is something like (xx-559) where xx is the tire width in mm and 559 the rim diameter.
    For instance Maxxis High Roller 26x2.35 is 52-559 and High Roller II 26x2.30 is 58-559!!! So as you see the newer 2.3 is wider than the old one!
    "Do not go where the path may lead. Go instead where there is no path and leave a trail" Ralph Waldo Emerson
    Sep 2013
    Quote Originally Posted by George Gr View Post
    My current tire ETRTO number is 54-599 and the tire I wan to change is 60-599, so able to fit wif 10mm clearance?
    If you do the math is 6mm more. It leaves a 2mm gap from each side. Pretty close to the edge...
    Fat-tired Roadie
    Nov 2007
    I bet you'll be fine. However, test-fitting is king.
    Sep 2013
    Ok I will buy one for testing thanks all!
    29ers Forever
    Reputation: CannondaleF9's Avatar
    Nov 2012
    I have a Trek Cobia and while a 2.35 barely fits, I cannot shift into the granny gear (one reason to go single in the front).
  1. Rear Tire suggestions that complements Weirwolf front tire
    By zgroove in forum General Discussion
    Last Post: 08-09-2013, 11:40 PM
  2. Replies: 3
    Last Post: 07-16-2013, 10:17 AM
  3. Replies: 16
    Last Post: 10-09-2012, 09:23 AM
  4. Filling tire with grass... makeshift flat tire solutions...
    By jimmay5469 in forum General Discussion
    Last Post: 07-18-2012, 09:02 AM
  5. Front tire and rear tire size comparison question help?
    By Yellowr6 in forum Wheels and Tires
    Last Post: 01-26-2012, 12:54 AM
