Results 1 to 11 of 11
    Sep 2013
    is 24mm rim enough to fit a 26◊2.35 tire?
    Hi! I'm a beginner in mtb n i would like to know if a 24mm rim is enough to fit a 26◊2.35? My current bike is a trail bike n wif stock 26◊2.1 tire and 24mm rim on it, I was thinking of going wider for tires for a better look on my bike but I see forums saying that if u go wider for ur tires u need a wider rim or it will damage both the rim n the tire. So is it safe for me to change to 26◊2.35? All comments welcome, thanks!*
    Reputation: MSU Alum's Avatar
    Yes, even if that's the external, not the internal width.
    Sep 2013
    Quote Originally Posted by MSU Alum View Post
    So ur "yes" means I can fit a 26◊2.35 tire to my 24mm rim?
    P.S: I gt what u mean nw thanks! Was blank in my mind just nw and asked a stupid question sry.
    I ride bikes
    Reputation: moefosho's Avatar
    Apr 2013
    My XT wheelset is 24mm wide and I run Nobby Nic Evo UST 2.35 tires. No issues.
    Sep 2013
    But I heard that your tire will be 2.2times of ur rim where 24mm rim will have a 52.8mm tire (26◊2.1) so if for 26◊2.35 tire will sum up to a 27mm rim. Is that true? Or u can play around wif the size?
    Sep 2013
    Quote Originally Posted by moefosho View Post
    Thanks! But will you need to run a lower or higher psi? Or just the same?
    I ride bikes
    Apr 2013
    I normally run them around 28-31psi. Tubeless.
    Sep 2013
    I run with a inner tube, same psi?
    I ride bikes
    Apr 2013
    Usually with a tube, you will run a higher PSI to prevent pinch flats. Some people can run 30psi though. Depends on terrain and rider weight, etc.
    Sep 2013
    Thank you all!
    Reputation: Reelchef67's Avatar
    I run 2.35 nevegals on my rear and a stick E 2.5 nev on the front . I am using mavic cross ride disc wheels. mavic says only up to 2.3. Nev's are are true to size btw I find I need to have a bit more air to keep them from feeling squirmy on rooty sections but have no problems even the 2.5 on the front which is massive. It actually measures to 27.25 almost 650b size....!
  1. thinest slicks for 24mm rim
    By engrmariano in forum 29er Components
    Last Post: 04-19-2013, 08:51 AM
  2. I need help rebuilding a 24mm I.9 hub.
    By bridgestone14 in forum Maverick
    Last Post: 03-25-2013, 03:58 AM
  3. 26"x 24mm
    By jperry34 in forum Wheels and Tires
    Last Post: 02-10-2012, 01:56 PM
  4. 24mm Travel on my SID, what?!!
    By Tjay in forum Shocks and Suspension
    Last Post: 06-04-2011, 08:39 PM
  5. 24mm to 35mm in Rims
    By B-RAY in forum 29er Bikes
    Last Post: 02-27-2011, 07:53 AM
