Results 1 to 6 of 6
    Reputation: time229er's Avatar
    Oct 2013
    2014 Reba RL stanchion lube?
    got a new 2014 bike with a Reba fork and although the 2014 manual does not mention stanchion lube (other than soaking the sponges prior to reassmbly), I am sure I read that you can improve fork performance with a "treatment". Has anyone used the Finish Line stanchion lube? They state it will not harm wipers/seals...can't get a good answer re oil contamination though.
    dru
    dru is offline
    It's a lube. Probably good for the seals. I use silicone spray on my Manitou and on my Marzocchi because that's what Marz recommends. Figure it will be good for the Manitou too. If someone gave me a bottle of Finish Line stanchion lube, I'd happily use that as well.
    occasional cyclist
    Dec 2010
    I've used the finish line stanchion lube and it works well. It is very "frictionless" and very slick, so it helps shed some dirt as well as keeping everything working smoothly. I can't say it's anything noticeable while riding, but definitely in the shop pushing down on the fork you can notice it being smoother.
    Here's a mod to increase small bump compliance. It starts at #72.
    Solo Air vs Dual Air
    I like the Finish Line stanchion Lube too.
    Oct 2013
    Quote Originally Posted by DennisF View Post
    thanks
    2014 Nail Trail 29...
  1. RockShox Recon Gold -- No Need for External Stanchion Lube?
    By BobaX in forum Shocks and Suspension
    Last Post: 09-12-2014, 01:44 PM
  2. Stanchion lube?
    By reedfe in forum Shocks and Suspension
    Last Post: 08-28-2012, 03:45 AM
  3. Do you guys suggest using stanchion lube?
    By sasquatch rides a SS in forum Shocks and Suspension
    Last Post: 11-18-2011, 03:24 PM
  4. Stanchion lube or seal lube?
    By beanbag in forum Shocks and Suspension
    Last Post: 05-10-2011, 01:57 PM
  5. Advisable to Drip Finish Line Stanchion Lube below Fork Seal?
    By Rei_Ikari in forum Shocks and Suspension
    Last Post: 02-06-2011, 04:17 AM
