Results 1 to 5 of 5
    2009 Tora sl solo air
    Just got in a 2009 tora sl solo air i got off of ebay. Does not come with instructions, its currently set a 80mm....how do i get it to 100mm? Thanks
    Pimpmobile
    It requires full disassembly and removal of a spacer.
    Service instructions here..
    http://www.sram.com/_media/pdf/rocks.../TM_MY08_E.pdf
    I think the info you need is near the end.
    Thanks Hamfis T. greatly appreciated
    Former Bike Wrench
    Quote Originally Posted by HamfisT
    Though not shown in the service manual, it does NOT require full disassembly. You can remove the Solo Air cartridge and remove or add spacers without pulling the lowers off. If you do the service with the fork lying horizontal, you won't even lose your splash lubrication.
    Pimpmobile
    excellent!
