Results 1 to 6 of 6
    2005 Specialized FSR XC for a new ridder
    this is the bike im looking at. i had a fsr a few years ago. it was stolen. really want to get back into ridding. im 5' 10" about 220 or so. would this be a descent bike for me?
    my stolen fsr was a fsr comp. bike was great never gave me a problem. its in ok shape. no dents or dings. few scratches.
    whats would be a fair price?
    will be riding one trails around where i live. like to jump to. thats always fun. some specs of it below. any in put would be great thanks
    2005 Specialized FSR XC Pro Disc mountain bike. The frame is a size medium
    Stand over height 723mm
    Top Tube Length (center seat tube to center head tube) 587mm
    Head Tube Length 110mm
    Head Angle 70.5
    Seat Angle 73
    Wheel Base 1075mm
    Chain Stay Length 424mm
    BB Height 325mm
    Frame: A1 Premium Aluminum butted frame, ORE top and down tubes
    Rear shock: 100mm travel Fox Float triad 3 position with propedal, lockout, or open
    Front shock: Manitou Splice 100mm travel with lock out and alloy steerer
    Brakes: Avid BB-7 Mechanical Disk
    Front Derailleur: Shimano M510 Deore
    Rear Derailleur: Shimano M750 XT
    Shifters: Shimano M510 Deore
    Cassette: Shimano 9 speed 11-34
    Cranks: Shimano Hollowtech, Octalink XT Spline
    Chain Rings: 22 x 32 x 44
    Pedals: Shimano SPD Clipless M505
    Rims: Mavic XM117 Disc
    Front Hub: Specialized Disc
    Rear Hub: Shimano M475 Disc
    Tires F&R: Specialized Adrenaline 2.0, Aramid Bead (about 50%)
    Seat Post: Specialized butted alloy
    Stem: 3D Forged CNC machined
    Support OUR Wounded
    Reputation: stumpy223's Avatar
    I am 5'8" and my medium 2001 stumpjumper is a little small for me (its the same frame as the 05 fsrxc) so the bike might feel uncomfortable. And alot of those bikes are going for 600-800 dollars in my area, at the high end they are very clean, hardly ridden and already tunes up, on the lower end they are rode hard and put away muddy.
    OK i might pass then. anyone else? thanks
    I think an '05 may be on the bubble for technology. For example, '08 shocks seem to be superior for the price point as compared to '05. Frames and transmissions may have only modest improvements since '05. Pivots also appear to have seen some improvement since '05 as well.
    It all depends on price, that bike should treat you good - but factor in the possibile cost of having to replace the front shock and then see if its still a good deal.
    ok thanks
    Reputation: onegymrat's Avatar
    I rode one for almost 2 years. A fine bike. Manitou fork broke twice and eventually swapped for a Fox F100RL. Highly upgraded later and was very content. Eventually sold the frame and switched most of the components onto an Epic frame. Would I still recommend? Absolutely! Great handling and easy to whip around.
    As for sizing, you're on the bubble of medium or large, as am I (5'9" and ride a medium). If you have a shorter torso than most who are 5'10", then medium is fine. If you're average proportioned or have a longer torso than most, definitely go large. This is for the FSRxc specifically of course, for an '05 up to '08. Goes for their Stumpy line as well in case you may be looking.
    As for the cost, I think if it's dent free and perfectly functional, $600 is a fine price. $800 is too much. It'll depend on your budget. Buy as much bike as you can in the beginning, no matter the budget. You'll thank yourself later.
