    Oct 2011
    2001 Rockhopper Pro vs 2010 Rockhopper Comp 29er?
    The 2001 is $175 but the fork is leaking.
    The 2010 is $550 with deore xt derailur and 29 inch wheels.
    This will be my first real mountain bike...had a walmart one a couple years ago, haha. The 2001 seems to have been outfitted with better components initially, but they're now 11 years old. I could replace the fork with a nicer new one and still come out under 550 though.
    Is the newer bike the way to go? My heart says yes, but the pocketbook says no!
    2001:
    Fork Brand & Model Rock Shox Judy XC
    Components
    Component Group Mountain Mix
    Brakeset ProMax linear-pull brakes, Shimano Deore levers
    Shift Levers Shimano Deore LX RapidFire SL
    Front Derailleur Shimano Deore LX
    Rear Derailleur Shimano Deore XT SGS
    Crankset Specialized Forearm 2 Comp, 22/32/44 teeth
    Pedals Shimano PD-M515 SPD
    Bottom Bracket Shimano BB-LP27, 113mm spindle
    BB Shell Width 68mm English
    Chain Shimano, 1/2 x 3/32"
    2010:
    FORK:
    RockShox Dart 3 SL for 29" wheel, 80mm, 1 piece magnesium lower, alloy steerer, adj. reb. damping w/ LO and preload adj., size-specific spring rates, spring assisted seal, disc only
    FRONT BRAKE
    Avid BB5, mechanical disc, 160mm G2 Clean Sweep rotor
    REAR BRAKE
    BRAKE LEVERS
    Avid FR-5, alloy, two-finger linear pull
    FRONT DERAILLEUR
    Shimano Altus, 34.9mm clamp
    REAR DERAILLEUR
    SRAM X-5, mid cage
    SHIFT LEVERS
    SRAM X4-R trigger
    CASSETTE
    SRAM PG-830, 8-speed, 11-32t
    CHAIN
    KMC X8 w/ reuseable Missing Link
    CRANKSET
    SR SunTour, Octalink spline
    CHAINRINGS
    42S x 32S x 22S replaceable
    BOTTOM BRACKET
    Shimano BB-ES25, Octalink spline, cartridge bearing, 68mm x 118mm
    Freshly Fujified
    Reputation: Call_me_Clyde's Avatar
    Buy the newer bike
    If it's in decent shape, buy the 29er. Bottom line, a 10 yr old bike is a 10 yr old bike. $550 for a relatively new 29er with decent spec is the way to fo, IMO.
    Bob
    P.S. Pocketbook aside, $550 is a drop in the bucket for a mountain bike of ANY quality.
    'If Wal-Mart sold parachutes, who would jump?' Frank Havnoonian (quoting his father) Drexel Hill Cyclery
    I would go for the 2010, I think overall it has better components than the 2001 bike. And you'll be quite sure that the frame is in good condition too.
    Oct 2011
    Went with the 2010!
    Bike actually had SR Suntour XCR lo 29 forks, not exactly how they compare to the Dart 3 I was thinking it had, but they at least seem to work well enough for my needs at this point!
  1. 2010 Rockhopper Comp vs 2011 Rockhopper
    By FL_rider in forum Specialized
    Last Post: 08-20-2011, 01:23 PM
  2. 2010 Specialized Rockhopper Comp vs 2011 Rockhopper
    By FL_rider in forum Beginner's Corner
    Last Post: 06-28-2011, 02:38 PM
  3. 2010 Rockhopper Comp SL 29er vs Trek/Fisher Cobia
    By 417brobinson in forum 29er Bikes
    Last Post: 04-20-2011, 05:30 PM
  4. Replies: 2
    Last Post: 12-13-2010, 03:09 PM
  5. Replies: 25
    Last Post: 05-21-2010, 08:25 PM
