Results 1 to 6 of 6
    2 Bolt Seatposts?
    Well, Im looking for a new seatpost for my bike. I see alot of these 2 bolt style. Will those work with regular rail seats fine? Right now my bike just has the straight shaft seatpost. Will I need to buy new seat mounting hardware?
    T.W.O.
    Reputation: mimi1885's Avatar
    nope, it's fine.
    And is 31.6mm basically the standard tube diameter? That's about 1 1/4 inches, and I measured my post diameter and it's only about 1 inch in diameter. Or am I measuring it wrong?
    T.W.O.
    standard? not really one of the popular one yes. The other is 27.2, 28.6, 30.9. Make sure you get the right one.
    R.I.P. DogFriend
    Reputation: jeffj's Avatar
    It should have the size etched into the post down near the bottom somewhere. They come in all sorts of sizes. 31.6 is a common size. That along with 30.9 and 27.2 are probably the most common sizes, but you should always know exactly what size you need, lest you damage the top of the seat tube from running the wrong size.
    For instance, a lot of bikes run 30.9, but some use a 30.8, even from the same manufacturer that also makes frames that take a 30.9.
    Ah ok, I have a 27.2 I was measuring it correctly.
  1. Replies: 27
    Last Post: 02-01-2012, 02:52 PM
  2. Replies: 7
    Last Post: 01-12-2010, 03:23 PM
  3. Easton 2-bolt seatposts?
    By GRAVELBIKE in forum General Discussion
    Last Post: 09-06-2007, 08:52 AM
  4. stuck bolt (sort of loose bolt too) on KLein Pinnacle Elite
    By pinguwin in forum Vintage, Retro, Classic
    Last Post: 03-09-2007, 07:16 AM
  5. 20mm bolt thrus and seatposts
    By da_eddio in forum All Mountain
    Last Post: 01-14-2007, 10:19 PM
