Results 1 to 7 of 7
    1999 GT Avalache... scrap or rebuild?
    Hey guys,
    I'm kind of attached to this frame, plus it seems still lighter than anything I can get in my price range ($1000 max) if I look into getting a new or used complete bike.
    The parts that mostly need replacing on the bike are the fork (ancient Rockshox Duke Race fork), chain and cables, outer and middle chainrings on the crankset, and rear deraileur. I would also like to replace rear brake, handlebars, and brake levers, but it's not a life or death situation.
    I feel like I'm looking at spending between 350-600 dollars on low and mid range components to turn this frame into a very decent commuting + weekend warrior machine. Thoughts?
    Jun 2012
    if the frame is in good condition and you'd rather save some money then sure, and your not to terribly hard on bikes, why not rebuild it. if you plan using and abusing, then i would put that money to a new bike, or a used newer bike than what you have now.
    what i would do is get a new bike. For me, new is used, but it'd be a 2006 or newer model for as cheap as i could, browse Craigslist in local and areas you wouldn't mind to drive to pick up a bike, be sure to get as much info as possible about it though so that you don't end up buying something that will take more money dumped into it to fix something that you didn't know about. Pinkbike.com also has a good rep, tha'ts where i would start, you can get them cheap there because many people on there are buying new bikes and need to make room so they sell there old bikes cheap to get them out of the way.
    Flow like water
    Reputation: DavyRay's Avatar
    You mentioned using it as a commuter bike. One point of reference: I bought a 2011 Kona Dew a few months ago. It was $410 at my LBS. I like vintage stuff, but sometimes you have to really figure up your costs. I also just have about enough time to clean, adjust and lube the bikes in the house now. A rebuild project would take away from my riding time.
    At this point, I'd rather ride more and not spend so much time on projects. Everyone's situation is different, though, and projects are fun.
    Reputation: theMeat's Avatar
    Could buy a used bike, ideally with cheap frame and good parts that you could switch over to your frame. Think when you add up all the parts you'd need $ wise and also time/research for the best parts and price wise, it'd just be faster and cheaper.
    Round and round we go
    no trees are safe
    Reputation: Millfox's Avatar
    Jun 2012
    If you like the frame than rebuild it.
    Fat-tired Roadie
    Nov 2007
    OP - sounds like a plan.
    Some things I'd be looking at as possible sources of problems:
    -Headset size. Probably already 1-1/8" threadless, which is fine. If it's something else, may be a problem.
    -Brake type. This is probably the biggest real change in current bikes. Disc brakes are ubiquitous on mid-level and high-end bikes now.
    -Fork travel. If you have one of the really short-travel forks, like a 63mm fork, a new fork will make your bike's geometry weird. If you have an 80mm fork, get a new fork that can be reduced to 80mm if you're not happy with it at full length. Note that using a longer fork than what the bike was designed for puts extra stress on the head tube, but I don't think people have problems with this in practice until they do something really ridiculous, like a DH fork.
    Reputation: JoePAz's Avatar
    May 2012
    Quote Originally Posted by kendobari View Post
    Hey guys,
    Why junk a perfectly good frame? 600 on parts will give you a better bike than $600 on complete bike.
    Joe
    '18 Specialized Epic 29", Vassago Verhauen SS 29", '13 Santa Cruz Solo 27.5", XC, AM, blah blah blah.. I just ride.
