Results 1 to 6 of 6
    Reputation: Danielrg_usa's Avatar
    130mm Recon on 26" inbred?
    I found a Inbred frame that I want to buy and have been looking for a fork to put on it if I do. I am on a tight budget so I am limited. I found a Rockshox Recon solo air that has 130mm travel and is in my budget. On-one says max travel is 120mm. However, I have heard that this due to a safety rating that is a bit overkill. Can I run the 130mm fork and be okay? I am not a hard rider and will be running SS. Link to the fork is as follows:
    Rock Shox Recon Solo Air 1 1 8" 130mm 26" Suspension Fork Bike 21 5cm New | eBay
    I posted this in the On-One forum as well but wanted to see what you guys here thought.
    Fat-tired Roadie
    Nov 2007
    I think it would be fine. Sometimes using too long a fork voids a frame's warranty, but you're buying used. Using too long a fork can make a bike handle badly, but IME 10 mm isn't much. You can probably space the Recon to a shorter travel later on if you like.
    Thank you Andrew.
    Well, frame and fork are ordered. I can't wait to get them in so I can put this thing together and ride. It has been almost five months since I have rode and I am ready for some miles.
    Fat-tired Roadie
    Nov 2007
    Post pics of the build when you start getting the pieces.
    Will do. Most of the parts are donors from my last bike so it won't be anything special. It will, however, be my first build so hopefully it goes smoothly.
  1. 2013 26" 130mm to 29"?
    By Sean Allan in forum Cannondale
    Last Post: 11-19-2012, 03:47 PM
  2. Replies: 0
    Last Post: 02-15-2012, 04:23 PM
