Results 1 to 8 of 8
Thread: 100mm to 80mm
    100mm to 80mm
    If my bike came with an 100mm shock can i put an 80mm shock on it? Or will it mess the handling up? Thanks
    that should be fine to only prob is if you go to a 120mm. Now that will depend too on how hard u ride it but to ans quest. that will work
    2008 Novara System 2.0
    Fat-tired Roadie
    Nov 2007
    I assume you mean fork...
    I stuck an 80mm fork on my Hardrock, which shipped with a 100mm fork. It speeded up the handling a lot. I thought it was a bit truckish with the stock fork, now it's a bit twitchy. On balance, I'd say I like it better.
    The only way to find out how it'll effect your bike is to try it.
    Ya, i mean for. I can adjust it to 120mm but i'm gonna go with 80mm. I dont do any jumps or ride hard, just the usual roots, rocks, curbs, and teeter-tooters
    I mean fork
    meow meow
    Reputation: b-kul's Avatar
    should be fine. handling will feel faster, maybe a little unsure going down hill.
    Professional Speed Bump
    Reputation: captainjoon's Avatar
    NOOOO! You're gonna go over your handle bar all the time!
    pedal pusher
    Reputation: f3rg's Avatar
    ^ Ignore that.
    I just reduced the travel on my 100m fork to 80mm, and it sharpened the handling quite a bit, back where I had it while running a rigid fork. If your bike came with a fork that can be adjusted to 120mm, then it was designed to take that, by the way. Still, your handling would slow down quite a bit like that.
