• 01-18-2013
    dansMTB
    Where are the bearings on the new rune and spitfire?
    On the links themselves, or in the frame, or combination of both?
  • 01-18-2013
    Dogboy
    Combination. It's pretty easy to see where they are located on the Banshee website.
  • 01-19-2013
    builttoride
    The bearings are located on the exterior linkage part at each pivot for superior stiffness and bearing life.
  • 01-19-2013
    the evil bunny
    It would be nice if Banshee would offer a bearing tool (like Transition does)
  • 01-19-2013
    MartinS
    They are pretty easy to remove, had no prob swapping out the ones on my Prime proto (they had to be swapped due to some proto-typing issues that are of course fixed for production) and I didn't require any special bearing tools other than a socket set and some quick-grips.
  • 01-20-2013
    bmxking45
    I wonder if banshee will be ffering bearing kits for replacement down the road
  • 01-20-2013
    MartinS
    They are very common sizes, easy to order from Enduroforkseals.com and cheap enough to order a set 'just in case'. I think the full set would run a hair over $40...
  • 01-20-2013
    MartinS
    FYI, I believe these are the Enduro Max bearing recommended replacement numbers are
    4 x 6001 2RS
    4 x 608 2RS
    The 6001 2RS' are $5.18 ea, the 608 2RS' are $3 ea, so $32.72 US plus shipping.
